RTX 3060 Ti Availability
guile
This Dreamcore built looks pretty good for the price
Anyway, they replaced the MSI Mortar B550M motherboard with the Asus Prime B550M-A Wifi which is a much worse motherboard (even worse than Aftershock's Gigabyte DS3H and Aorus Elite packages), thus making the package not so attractive anymore.
Skip to 15:00
hafiz116
If anyone got a PSU bundle do share the model of the GPU and PSU. I suspect this is just a marketing ploy and you will ultimately end up paying for it anyway.
Dolphin1977
went pcthemes at 11.05am.. bought the last piece gigabyte 3060ti $759
den walk around ssrr.... went a few shop saw msi gaming x, asus strix.. all of them for full system only. saw a aorus master 1070 but selling at crazy price $1100
Dolphin1977
gigabyte 3060ti gaming oc
gigabyte P650B
$759
ya i also feel price higher... msi gaming x if have stock only $729
tigerwoods
Got free PSU bundle ?
Phen8210
why dual cooler palit ones got issue?
its cooling solution might not be good enough.. tbh even the ones with beefy heatsink have louder noise and worse temps than the FEs.
I have tried asus dual as well and even though its almost 3 slots thick the temps can hit 83c and start to throttle itself, this is already at 80% fan speed and the noise is pretty noticable. Reapplied to kryonaut already btw.
So yeah, if possible go 3 fan design unless there is space constraint.
Phen8210
for these cards 2 fan design, probably can consider palit jetstream and galax. i m not just talking about 3060ti only as the temps are just as hot as 3070.
zotac twin edge, msi ventus 2x and palit dual is just a big red flag.
Adam80
3060ti Gigabyte eagle $750 cheap?
my friend got lobang
Sent from Sony XQ-AT52 using GAGT
imnuts-
Skip to 15:00
I asked dreamcore why they downgrade the mobo, and they told me it's more ex :spin:
guile
Wtf? It's one of the cheapest B550m with WiFi built in. It doesn't have 2.5g LAN, worst sound chip and no heatsink over the M2 slot. Lol
Sent from Samsung SM-N975F using GAGT
minuteez
https://www.guru3d.com/articles_pages/palit_geforce_rtx_3060_ti_dual_oc_review,6.html
https://www.guru3d.com/articles-pages/zotac-geforce-rtx-3060-ti-twin-edge-oc-review,6.html
https://www.guru3d.com/articles_pages/msi_geforce_rtx_3060_ti_trio_x_review,6.html
https://www.guru3d.com/articles_pages/gigabyte_geforce_rtx_3060_ti_gaming_oc_pro_review,6.html
https://www.guru3d.com/articles_pages/asus_geforce_rtx_3060_ti_strix_oc_review,6.html
Looks like the FE is the hottest card of them all. Based on these, the tri fans generally run bout 3-5 degrees cooler than the duals.
I got the dual fan palit cos Im using 500w PSU & didnt want the hassle of replacing PSU etc. GPU does run at 80ish deg but I dont see throttling yet.
It does get LOUD like jet engine & it causes the rear of my case to warm up quite a bit.
Firstly, cheap Palit also got LED. :s13:
The parts circled red gets very warm when GPU in load. The GPU exhausts all the hot air from the fins just above the GeForce wordings. It blasts onto the side panel & gets pushed up & gets sucked out by rear fan.
Im using Tecware Evo Nexus which is not exactly a good airflow case, but Im wondering if theres anything I can do to reduce GPU temps or a new case is needed. Currently 2 input front & 1 output rear.
From what I see on YT, adding one additional input fan & top exhaust fan dont really help much but I wanna get 2nd opinion from you all.
Without side panel, GPU runs at bout 75deg.
croc1977
so if palit triple can no issue?
