ic....
if u looking for cheaper ones....this is the cheapest i can find.
$300 - coupon = $260~$270
https://www.qoo10.sg/g/681770564/ (non ref link)
Thanks so much. But the sound from the video review is super loud hahah
ic....
Hi all, need some advice. Bought a 4room in Simei and based on the wife's design, the kitchen walls are knocked down so the kitchen/dining area is one large L-shaped space (slightly less than 600sqft). My ID and gaincity says that a 24k BTU for this outside space is not enough - is this true in your experiences?
Bc of this, gaincity suggested i get a Toshiba system 5 (apparently the Toshiba sys5 compressor is the only brand that can be bracket mounted because it's less than 80kg). So 2 fancoils in the outside space and 1 each for the rest of the rooms. Do you think this is feasible?
Thanks. Any advice and recommendations is appreciated.
ignore the area factor/btu
aircon works by cycling the air in room and cool it. when u got 1 long stretch or unevenly room, it is impossible to cool it efficiently or achieve constant temperature....somemore kitchen generate heat.....
e.g
If area is square, we will setup 5 aircon unit
if area is uneven, we will setup 8 aircon unit to cover the blind spots....
my friend's living room is connect with long corridor.....the tech recommend to do partition for the corridor to max cooling for the living room.
I have a long kitchen / dining area that's 8-10m long. My 24k does the job, but if I were to revisit the process, I'll install 2 12k units at separate positions instead.
@wongminmin: how long is a "long stretch"? my combined outside area is 10m x 7m (for the respective sides of the L). We're also not looking to cook so regularly, and if we do, we won't be turning on the aircon outside (projected only for night time / when guests or family members are over). So all I'm looking to achieve is a cool (not cold) atmosphere, especially in the living and dining area (kitchen is not impt). I would also like to install a screen door/moveable partition between my living/dining area and my kitchen, but the wife has ideas about the aesthetics which, well, rules that out.
ok give u 1 e.g
With peter setup, he find it cold but with the similar setup, your wife don't find it cold. Cause different environment and person.....
so for the safer approach, ur id and contractor suggest 2 aircons split units.
actually if not cool, u can always use fan to circulate the airflow.![]()
hi everyone, does big retailers like GC, Best Denki, Courts etc visit twice for installation? My ID is pushing me to use his aircon contractor as they will come first time to lay piping, then the ID will waterproof/tile, then the aircon contractor come a 2nd time to install fan coil.
which air conditioner is best buy now?any suggestion?need inverter and im thinking to get mistsubishi inverter but not sure whether they are still good brand to buy
got $, anything is possible...i think $100 to $200 to replace.Resale flat, the air con there got one box up.. That one look a bit old.. Possible to replace?
And that one look a bit ugly lol. Possible to style it?
from 1 of users i read, the compressor is extreme quiet.Anyone used Toshiba Youme and have any feedback on the cooling strength & noise? Can’t seem to find much reviews online.
