TV repair discussion thread II [consolidated]
bdaddy
KDL-55W800C. Didn't do firmware update before. However, when problem started I tried to reflash using USB but it didn't work coz tv keeps rebooting. Guess tv is a goner now.
What is the TV model? This is a common problem for most Sony android models.
If you have done a firmware update recently, rebooting is a common error. Sony does not seem to honor any repairs due to software glitches like this. Need to reflash the original firmware or to factory settings.
limtk55
There are 2 ways to reflash. One by USB and one by an external programmer. For that, you need specific equipment. The difficulty is in getting the firmware for your specific TV.
matey1982
hi guys
if repair the existing TV screen backlight (other thn the white light on the screen, the tv is still working fine)
vs
buy new tv set
whh is the better option cost wise?
tv was bought in 2014
LG 47LB582T-TB
matey1982
Mine is $300+ for backlight.. if panel spoiled while changing = gone case waste money.. LG tech don't even keen to try after knowing my tv is so cheap.. how much u paid for the tv last time??
your LG tv was bought when???
cscs3
hi guys
vs
buy new tv set
LG 47LB582T-TB
LG backlight is easy to get. Try searching in Aliexpress or Taobao.
matey1982
reliable or easy to self instal?
to be honest i wont want to self repair with 1/2-baked skills later end up damage the tv further
or shd i just hold back and wait to buy a new one?
weeza77
Check out youtube videos on the repair and decide if you want to give it a go. If the parts is cheap I'd say why dont give it a try.
Or contact a poster here and ask for quotation?
pohw0008
2017.. mine is 55 inch LG tv.. don't bother calling LG tech.. waste time.. i let limtk55 try repairing.. if can fix will put in mbr.. but now tv quite cheap imo.. less than $1k will get a cheap 4k tv..
matey1982
yours bought in 2017, warranty finished liao?
i ask LG main service ctr...quoted $170.25 (if i hear correctly) just for technician come down to troubleshoot (havnt count in the cost of the spare part)
some of the other tv repair numbers tht i whatsapp earlier quote me around $200-$250 to repair
i was like haiz
sua liao
use the tv until dong buey diao liao then change tv set
cscs3
Many steps, so is best to be careful. If TV still useable, and you have no confident. Dont try. If already cannot watch, give it a try as you wilk feel much rewards if successfully fixed by diy.
Too bad, yours is 55in. I have LED back light taken out from my friend 42in LG TV. He got a crack screen, also cannot claim warranty.
cscs3
i was like haiz
sua liao
Yes, now a day labour charge is super high.
weeza77
i was like haiz
sua liao
Have you tried to pm limtk55?
matey1982
think u got it confused.
mines was a 47'' LG tv
the 55" LG tv is another TS's
pohw0008
Got it in April 2017.. already more than 3 years..
i was like haiz
sua liao
cscs3
Thinking of changing TV for the new year but what usually signs of TV going bad?
Old TV worth nothing. Unless you have money to kill, wait till old TV go bad. By that time you may be able to get newer model or old model at cheaper price.
C_boliao
My LG oled just spoilt. Got lines on the middle of the screen + auto shut down after 2mins.
it happened after water spilt on it.
Still under warranty, but I think LG doesn't cover it.
Worth to repair?
franky
I have a Sony KLV-46X350, When i switch it on, the power LED light will blink twice. I have managed to get replacement for the power and main board. Can anyone assist me to replace the boards?
limpingsim98
Worth to repair?
For OLED panel, no sub components is repairable from field. So if you TV no longer under warranty, it is basically scrap value.
Hopefully the water only affected or burn some pins on connector.
