Story time? Did they replace it immediately or did you have to come again to collect?
Replace it on the spot
Look under Accessibility options.
Hi, i am planning to get a xiaomi 4s 65" TV.
I am planning to output the TV's audio from netflix and other apps to my yamaha receiver.
Does the TV have optical output? I understand that it has HDMI ARC but unfortunately my yamaha receiver does not have HDMI ARC. Is there any way that i can work around this?
Thanks in advance.
From this video :
At the 7:30 mark, it shows that this has optical out. Is that what you are referring to?
This is 4X. I believe the other guy wanted to get the 4S
My less than 3 months old xiaomi tv just turn black screen, and whenever turn on just black screen. Indicator light turn on, one to two seconds, thin line on top of screen lid up and full black screen. Purchased from mi store funan. Anyone with same experience ?
Try and see whether you can go into Recovery.
you don't need the cable to check the settings on your TV. You can go through it and see if it's a hassle to you to switch. May be you're ok but others at home may find it a hassle. eg after you watching some muscials, then you just off the TV. Next time you on the TV to watch the news, there is no sound from the TV speaker until the person goes through the settings to change it back to TV speaker.
When I'm on TV speaker or HDMI ARC, when I switch to SPDIF, the audio is cut off, so I presume it's going to SPDIF.
Got hold of an optical cable, like the audio output to my sound bar watching youtube, seems to have less lag.
I see "getting data" on free to air tv channel....sometimes it is stuck on the screen. Any idea what caused this?
I think there is a settings to adjust the lag, fyi.
Does switching on the TV switch on the sound bar also ? And off as well ?
You can control the volume from the TV, right ?
This matter is settled. Xiaomi came and replaced a new one
