I just top up water.. Maybe i should try windscreen cleaning solutiondo you have windscreen cleaner solution in your wiper water tank or plain water?
Windscreen wiper during rainy days
Hi guys, aside from cleaining the wiper rubber strip regularly, how do you ensure good vision on rainy days? Is there any solution you apply to the windscreen or rubber strip ?Realised during the recent rainy season when i use my wipers, the front windscreen still is a little blur. Not sure whats the issue or how to improve it..
Thanks. Will try!Get it coated to repel water. Then uses less wiper action, wiper longer life.
DIY can liao.
Just visited Mazda Service Center on Saturday to check on the suspensions and mountings as my warranty is coming to an end...brought up the issue on changing ATF to the tester...his reply was no need to change, it is lifetime according to Mazda Japan. Anyone here change the atf before?
Sent my car for servicing at TEK. Was offered this promo package for CX-3 above 20K mileage. I overheard similar promo package offered to owners of other models as well.
Promo package for CX-3
30% off for next 30K, 40K and 50K mileage servicing ---> Net Payable $825
50% off for next 30K, 40K, 50k, 60K and 70K servicing---> Net Payable $1229.43
30%* off 2 year Extended Warranty or 140K mileage --> Net Payable $1229
50%* off 2 year Extended Warranty or 140K mileage --> Net Payable $999
* I would think that if you opted for the 30% discount servicing package you are entitled only for the 30% extended warranty.
Promo only valid till end Jan. Looks quite attractive I must say.
Thanks to all for the advice. Was rather skeptical as Tester (TEK Ubi) told me owners changed ATF never do programming and there are cases that the gearbox was faulty after the atf change and a gearbox costs $16,000! Anyway I just ordered online at shopee ATF-FZ. Plan to change it at 50000km.Not just this brand suggested that ATF is lifetime... VW also. To have a peace of mind?Just continue to change it outside as it won't cost you much, since oredi spend so much on the car.
u see the market, why are shops selling mazda branded atf ?
Watch this:
I took over a Mazda recently at 80k mileage, had the ATF changed. It came out brown. The new Mazda ATF is greenish-blue in colour. The workshop mechanic said the ATF hasn't been changed at all.
For peace of mind, just change the fluid. It doesn't cost as much as repairing the entire gearbox.
:s13Thanks bros for your experience on the CX-3. Agree it seems too tight for a compact SUV. Just came back from the showroom and kena poison by the CX-30 instead haha... Wonder if it's worth it compared to other crossovers in the same class.
Did you just drive 20k+ only in three years?
It seems the wing mirror motor is another issue for Mazda 3. Mine (LH) was changed the previous week at TEK Penjuru. December 2020 just changed one of the engine mounting (hydraulic) at TEK Ubi.
No, my car is 1 year old. The warranty that comes with car is 3 years. So this extended warranty package offered should be covering year 4 and 5.
Did you asked tester why need to perform progamming after each ATF change?
I’m driving a 2018 Mazda 3. Both wing mirror have problem opening. Send to penjuru, they only change left wing mirror. Few month later send to Ubi, they say no problem with right wing mirror. If want to change, take video of the fault and come back again. Suspension have knocking sound, they claim it’s normal. Gave up on TEK. Total waste of time ding dong at TEK. All these happen within warranty period
