Samsung Galaxy Note 20 | Note 20 Ultra
nuscape
Korean set have any issue?
Sent from OnePlus KB2000 using GAGT
Korean set = +65 contacts, S Pay reward, Keyboard diff layout, warranty issues
HK set = 5G, S Pay reward, keyboard diff layout & warranty issues
SG set = games performance issue & batt life lesser for some.
Don't buy = no issue �
Sent from Samsung SM-N986B using GAGT
xiaosen
Don't buy = no issue *********
Lol kk noted.
xiaosen
Want buy, buy local set better.
Buy export later spoil headache
OK noted bro. I am ok with export set but never brought 1k above phone export set. So seeing what is the pro and con.
Dvoiddeckbench
Been using for a month after changing out from Huawei P20 Pro. Battery definitely not as good as my previous phone but still can last me throughout the day without any issue.
After update, my Note 20 Ultra not as hot unless I spend a significant number of hours scrolling tik tok.
Overall I think its a great phone. But then again, I don't use a lot of features. So its alright for me.
ccmheoa
Currently no 5g or have 5g , seriously have zero effect.
Take the hk set better cause can dual SIM.
By the time 5g matters, you won't be using this phone anymore
If you don’t mind no 5G
Korean set can support but HK sets can’t
ccmheoa
Just sold my mate 20x, amazing battery life!
Too bad for huawei, if not for the GM's problem. I would probably own the mate 40 pro now
davidwong
Why not get a new one since it’s still available?
If it’s cost, if a person willing to sell you a flagship phone at Low cost you should be weary.
If a person is selling you the same flagship phone with almost the same pricing as new, might as well buy new as you are already paying so much for it?
hi,
i am considering to get a used samsung note 20..
any recommendation?
Zinc-Oxide
I agree with you 💯. used and new set is like $50 different only.
I agree with you ��. used and new set is like $50 different only.
Where u guys see 50 bucks difference?
Anyway would like to know the options to get used phone.. if significantly cheaper then will consider.. of course the seller need to be reputable..
I see a source it can be 30, 35% cheaper
Zinc-Oxide
Just go through carousell and look at the listing
Zinc-Oxide
Sorry if I didn't said it correctly, we are referring to the street price. New one is around 900 and the used one is 850 or a little bit below.
Zinc-Oxide
Go directly to seller is better, you get good price but not from secondhand shops. Meanwhile, slowly go through all the list in carousell, becareful with those low quality pictures, this is how they try to smoke you.
I rejected a few sellers when I purchasing note 9. Told me screen is perfect no scratches, when I checked under the sun, is badly scratched up. I just said I don't want this set anymore within 1 min. you are the buyer and you have the power to reject.
Go to whymobile and check how much they taking in, is just a rough gauge of the market price.
that would mean deal direct with the seller?
would it be better if going thru shop that sell used phones?
