Korean set = +65 contacts, S Pay reward, Keyboard diff layout, warranty issuesKorean set have any issue?
Sent from OnePlus KB2000 using GAGT
Lol kk noted.Korean set = +65 contacts, S Pay reward, Keyboard diff layout, warranty issues
HK set = 5G, S Pay reward, keyboard diff layout & warranty issues
SG set = games performance issue & batt life lesser for some.
Don't buy = no issue *********
Sent from Samsung SM-N986B using GAGT
Want buy, buy local set better.
Buy export later spoil headache
OK noted bro. I am ok with export set but never brought 1k above phone export set. So seeing what is the pro and con.Want buy, buy local set better.
If you don’t mind no 5G
Korean set can support but HK sets can’t
Been using for a month after changing out from Huawei P20 Pro. Battery definitely not as good as my previous phone but still can last me throughout the day without any issue.
After update, my Note 20 Ultra not as hot unless I spend a significant number of hours scrolling tik tok.
Overall I think its a great phone. But then again, I don't use a lot of features. So its alright for me.
hi,
i am considering to get a used samsung note 20..
any recommendation?
Why not get a new one since it’s still available?
If it’s cost, if a person willing to sell you a flagship phone at Low cost you should be weary.
If a person is selling you the same flagship phone with almost the same pricing as new, might as well buy new as you are already paying so much for it?
I agree with you ��. used and new set is like $50 different only.
Where u guys see 50 bucks difference?
Anyway would like to know the options to get used phone.. if significantly cheaper then will consider.. of course the seller need to be reputable..
I see a source it can be 30, 35% cheaper
Just go through carousell and look at the listing
that would mean deal direct with the seller?
would it be better if going thru shop that sell used phones?
