Gaming Desktop
tigerwoods
I think for inexperienced individuals,it's a risk to go Sim Lim to buy IMHO
Will consider AS
I am AS user, just bought it recently.
You can ask me anything if have queries.
You can check out my unboxing experience if you want
Extremme
LEVEL 6 AMD : R5 5600X + RTX 3070 [$2415]
AMD Ryzen™ 5 5600X
GIGABYTE B550M DS3H Motherboard
Zoomflow 240xt Watercooling
16GB 3600mhz DDR4 (8x2)
ZOTAC RTX 3070 TWIN EDGE OC 8GB
1TB AFTERSHOCK GEN4 PRO Ultrafast SSD (NEW! E18 based) (R 7000 W 5300)
FSP 650W 80Plus *Bronze Certified* PSU
INTEL AX200 Wireless WIFI6 + Bluetooth
6x Addressable ARGB fans
RAPID High Airflow Mesh Chassis
LEVEL 6 INTEL: I7 10700KF + RTX 3070 [$2465]
Intel Core i7 10700KF
ASROCK Z590M Phantom Gaming 4 Motherboard *New!*
AFTERSHOCK Glacier Series 240 Watercooling
Gigabyte RTX 3070 Gaming OC 8GB
1TB Samsung NVME M.2 SSD R:3500 W:3000
Premium Aorus AX Wireless Wi-Fi 6 + Bluetooth Included
6 x Addressable ARGB fans
*Special PRISM+ Monitor Bundle Price*
I think Storage is very important. Anything below Level 6, the storage seems too limited. Which level 6 is recommended?
I think AS dont come with mouse, keyboard and Office :s22:
Is this better than my DEL G5?
LEVEL 5 AMD R7 3700X + RTX 3070 [$2215]
AMD Ryzen™ 7 3700X
Gigabyte A520M DS3H Wifi Motherboard
16GB 3600mhz KLEVV BOLT XR Memory (8x2)
AFTERSHOCK M-40 Frost Air Cooling
512GB SAMSUNG NVME M.2 SSD R:3500 W:2900
FSP 650W 80Plus Bronze Certified PSU (H3-650)
6x Addressable RGB Fans
3 Years Warranty (1st Year Onsite Pickup and Return)
occifer
Not good enough imo.
32gb ram at least cmon
For PSU, get a bigger good brand like seasonic 1000w...can last 8-10 years
And u definitely need more SSD and HDD space.
Sent from myphone using GAGT
tigerwoods
AMD Ryzen™ 5 5600X
AMD Ryzen™ 7 3700X
Just for gaming LEVEL 5 AMD R7 3700X + RTX 3070 is good enough, can save you some money for a new ssd.:s13:
All will perform the same when gaming in 1440p
localITguy
Suspended
AMD Ryzen™ 5 5600X
AMD Ryzen™ 7 3700X
try other SI instead, unless u are brave, won't suggest you aftershock
GotBetrayed
Do check out rtx 3070 vs gtx 1660 super, heaven and hell difference.
Get This can Liao:
1975 sgd aftershock combo
Intel i5 10600KF
ASROCK B560M HDV
*New next gen B560 motherboard*
AFTERSHOCK GLACIER 240mm Watercooling
512GB Samsung NVMe M.2 SSD R: 3500 W 2900
Intel AX Wireless Wi-Fi 6 + Bluetooth Included
4x Addressable RGB fans
Extremme
Get This can Liao:
Intel i5 10600KF
ASROCK B560M HDV
My frd's son got this last week. So was also thinking might be good enough. Perhaps add the SDD
congster2
All these look like a lot of money to spend for the kind of games you are playing. maybe easier to pick a budget config and adjust from there.
Extremme
if only gaming, then 16gb is enough. 32gb recommended for professional workloads.
The AS folks recommended me this based on my needs. She said more than enough :
https://www.aftershockpc.com/welcome/rts_details/3548
AMD RYZEN 5 3500X
GIGABYTE A520M DS3H Motherboard
16GB 3600mhz Klevv Bolt XR Memory (8x2)
GIGABYTE RTX 3060 EAGLE OC 12GB
AMD Wraith Stealth Air Cooling
4 x Addressable RGB Fans
On-Board Wi-Fi & Bluetooth Included
midlusionz
Another thing TS might want to consider is, how long do you wish this build to last before your next new pc then you can decide on the tier of hardware to go for
Extremme
YEs this is what I told her. I hope its not far fetched...I said 4 years at least haha
CopySeeSewDye
I think this is ok for the games u gonna play, just that if u can, ask for 3600 instead of 3500x to double the thread count at a small increase in price.
FYI, the website promo said superb 1440p performance but that is probably only true for not so demanding games that u listed. I can assure u if u gonna play AAA titles (cyberpunk, control, etc...) at even high quality on 1440p, it is not gonna have that superb performance at all.
Ah Tiong Bu
AMD RYZEN 5 3500X
If you connect your PC to the network with ethernet cable, you might not need the wifi. If that's the case, you can check if your motherboard has the non-wifi variant to reduce your cost.
Also you can consider adding a cheap HDD to increase your storage. 512GB not enough for multimedia files, softwares and games.
Extremme
All these Level 2, 3 4 AS models are pre-built so cant customized that much. I can add 1TB 7200 HDD though
I also think 512GB SSD is not enough but I cannot add another SSD or upgrade to 1TB SSD already as per the AS.
My kids typically uses Youtube alot, Minecraft, Roblux and occasionally video edits using paid Wondershare application
tigerwoods
You can always add in your own HDD if need more space.
