AFTERSHOCK PC - Now featuring Nvidia 10 series graphics cards!
regionmaster
APEX 15X
Intel i7 10870H 8 Core Processor
NVIDIA GEFORCE RTX 3060 6GB GDDR6
15.6" QHD 165HZ Wide Color Gamut Display (2560x1440)
16GB DDR4 3200mhz (8x2) Dual Channel (Operates at max 2933mhz with intel laptops)
512GB SAMSUNG NVME M.2 SSD (R: 3500 W: 2900 )
Per Key RGB Mechanical Keyboard with NKEY Rollover
Intel AX 200 Wifi6 + Bluetooth 5.0
Versus
FORGE 15X
15.6" FHD 144HZ Wide Color Gamut Display (1920x1080)
16GB DDR4 3200 Mhz Memory (operates at 2933mhz with i7 processors)
512GB NVME M.2 Klevv SSD
Intel AX200 AX Wifi+BT (Next Gen High Performance WIFI)
Single ZONE RGB Keyboard (silent)
$2240 vs $1835, how to compare this two ?
I guess screen and keyboard matters nothing to me, so itshouldn't be worth the $400 more for just the SSD right?
s7460597
My son's 2 year 8 months mx15 motherboard just died. Replacement is $700-800 according to aftershock.
Out of warranty.
have to get a new one. :(
gibson7
Out of warranty.
if the motherboard can last another 2 more years, I think still ok. compared to splashing out another 1-2k.
Sent from Xiaomi M2007J3SG using GAGT
s7460597
Ok will see if can get reasonable price replacement.
flowerpalms
Out of warranty.
Its aftershock, what you expect?
Posted from PCWX using A simple life, not a simple thing 🙏🏻
reveton28
Just wanna ask, anybody using the Slate 15 model? Been experiencing battery issue (sometimes just shuts itself after startup or just prompts battery low and just shutdown)
saberlancer
Mine diff model but also has shutdown issue. However bring back servicing also no use because is random and canot replicate the problem so nothing is replaced or done at all. Now warns frds to stay away..
randomA
Said it was over voltaged... perhaps lightning? Fixed it quickly and I’ve gotten it back. No cost as it’s under warranty. Better buy a surge protector.
how does this even happen to a laptop??
lightning even?
KirinXHell
Currently now have issue with the PSU whirling/buzzing sound & black screen no display without error code while gaming for my desktop from aftershock too.
I7-10700KF
Gigabyte Z490M Gaming X Rev1
Gigabyte RTX 3070 Gaming X 8G
Klevv 8GB x 2 DDR4-3600MHz
FSP Hyper Pro 650W
pylpoh
Is aftershock laptop a reliable buy? I'm planning to get one...but the general impression is bad customer service and short lifespan.
Reibunn
My Aftershock S-15 (i7 7700HQ, GTX1060) is still going good, after 4-5 years. They still accept my laptop for general maintenance.
