diy or contractor?cut out that tile.....
yes, but will leave a mark after patched with white cementDiy type ‘Cement’ ... i done on walls ... tiles ... u go diy shop or see YouTube
i want to patch old drill holes, not drill new onesiirc they stick a duct tape over the area that you want to drill. then drill into it.
diy self-fix got sell or not?put teh siao there use hair dryer heat until harden
should be almost similar color
yes but still can put what else to make the texture less obvious?it's called putty. few dollars a tub nia
to patch you need to buy the plasters. either a tub or buy the powdered form (mix water).i want to patch old drill holes, not drill new ones
cut from another tilediy or contractor?
where to find back the exact hdb wall tile?
My tiles were light grey color, and it was the corner tiles that got chipped off ... so i cement it then sort of paint over it ... still ok.yes, but will leave a mark after patched with white cement
i want to make it as close to original finish of the ceramic tile as possible
