how to fix old drill holes in ceramic tiles?
zzzzzzz
how to make it as close to the ceramic tile's finish as possible?
:frown:
Bunknifer
Diy type ‘Cement’ ... i done on walls ... tiles ... u go diy shop or see YouTube
Bwaysa1gan
put teh siao there use hair dryer heat until harden
should be almost similar color
New Eden
iirc they stick a duct tape over the area that you want to drill. then drill into it.
read wrongly.
zzzzzzz
yes, but will leave a mark after patched with white cement
i want to make it as close to original finish of the ceramic tile as possible
:frown:
New Eden
i want to patch old drill holes, not drill new ones
:frown:
to patch you need to buy the plasters. either a tub or buy the powdered form (mix water).
can't really make it just like the tiles anymore. drill another hole and cover it with an art piece or something?
Bwaysa1gan
diy self-fix got sell or not?
:frown:
have lah - think now is call self fix. got different colors also.
so depend yr wall tile simi color u buy something similar lah
u sway if u tile is the pattern one then the hole there sibeh obvious cannot find color mix match
then i think u buy the nearest color and use hair dryer heat then make smooth filing already use sticker cover
Don_Juan
yes but still can put what else to make the texture less obvious?
get matching paint with tiles to touch up the putty to make it less obvious
sTiCkY
best is use white putty for light coloured tiles rah :frown:
then colour it to the nearest colour...
after that ask chiur mummy to check if she notices it :s13:
Bunknifer
:frown:
My tiles were light grey color, and it was the corner tiles that got chipped off ... so i cement it then sort of paint over it ... still ok.
can use putty to put over it. But depends on the color of chiu tiles ... :s17:
