Yes disney+ is supportedPlanning to get this chromecast with google tv.
1) Is Disney+ app supported in this device?
2) Is the overall browsing experience smooth or laggy?
1) supportedPlanning to get this chromecast with google tv.
Supported means I'm able to download the app from the play store?1) supported
2) dunno what's your expectations. You can watch some review videos from YouTube. To me it is good enough but maybe a little bit lag occasionally
Read HWZ Forum Rules!
yes, and watch contents using the disney+ app on the google tv chromecast.Supported means I'm able to download the app from the play store?
Ok thanks man.. still deciding to get a tv with android tv or just use current tv with google tv chromecast.. any suggestions?yes, and watch contents using the disney+ app on the google tv chromecast.
I bought it for hbo and apple tv+ apps as my tv does not have them. But recently, these apps are released, so my chromecast is quite underused
Mine is LG, that made me buy the chromecast. But recently they upped their game by releasing hbo and apple tv apps so I started using less of my chromecastIf you only use apps like Netflix, HBO and Apple TV+, and if your TV has already built-in apps for these kind of streaming services, then you do not need an Android TV box.
Just an example, Samsung Smart TV and LG Smart TV are not that smart and ofthen it is a good idea to get an Android TV box to go with them, but if you are only using the apps it already has, then no need to get an Android TV box.
Ref: limited apps for Samsung and LG, compared to Android TV OS
https://www.samsung.com/sg/tvs/smart-tv/apps-on-smart-tv/https://sg.lgappstv.com/main
Mine LG but i lost the remote controller and the smart tv might not be working anymore.Mine is LG, that made me buy the chromecast. But recently they upped their game by releasing hbo and apple tv apps so I started using less of my chromecast
Your use case looks fine but without tv remote, how to change the inputs or v turn on the Tv?Mine LG but i lost the remote controller and the smart tv might not be working anymore.
For me, I only want to watch Netflix, Disney+ and my YouTube premium. I think Chromecast with Google TV will be fine for me based on my use cases?
