watzup_ken
- Nov 21, 2003
I generally don't look at the specs of the thermal compound or pads. The specs don't tell you how the paste performs longer term. As elmariachi mentioned, some of these thermal compounds and pads comes with very impressive specs. Sounds good on paper, but performance degrades quickly due to the high heat even though you may observe a few degrees drop in temps at the start. Personally, I prefer MX4 in the past over Thermal Grizzly (which cost a lot more, defaced a few of my coolers' coldplate, and degrade quite quickly over time). Now I am using SYY, which is harder to apply, but works just as well and more durable. I feel the more "runny" the thermal compound, the faster it dries up.
Just to share the results between MX4 and SYY in my Maibenben MiniPC,
MX4 - CPU max @ 87.1 deg C
SYY - CPU max @ 83.9 deg C.
MX4 - GPU max @ 80.7 deg C
SYY - GPU max @ 75.9 deg C
Results taken after looping Heaven benchmark for a couple of runs. Application of thermal compound is also fresh for each test.
Over time, I've not heard the PC ramp up its fan speed, unlike when I was using stock and MX4 thermal compound. It has been at least 5 to 6 months since I've used SYY on this PC.
