KnyghtRyder
 - Jan 3, 2002
how old is this fan? most of those sold in last 10 years no longer use greased bearings any more and they don't suck up dust and grime like the really old ones. Nowadays all use graphite-based lubrication.Most straightforward to try. I googled.
Problems with the bearings
As time passes by, your fan might start slowing down because of the dust and dirt formed inside it. It may be hard to understand at first, but with time dirt and oil gets formed in the bearings of your fan what makes it harder for it to spin the blades. That is why you should try to clean it regularly and oil its motor and bearings as necessary in order to prevent such a thing happen.
However, if your ceiling fan has already started to slow down, you can fix it just by cleaning its bearing. The process is simple and quick. Remove the blades of the ceiling fan, if they are removable. If not, just open the fan, and clean the bearing with a wet tissue then let it dry. If the dust has formed layers, try harder to remove it with a pointy tool. Do it slowly and carefully. Make sure the ceiling fan is off when you do it and then add oil.
