Which one will you pick? TV or Projector
TrueBeliever_jh
WW1 Flying Ace
Sincere opinion - just get the biggest TV you can reasonably afford.
Projectors are too finicky - the lamps got life limit one, the lumens not bright enough to use in a lit room, must find a good spot to mount the projector, must find a good spot to put the screen or if projecting onto a wall must make sure the wall surface is matt and ideally white etc.
aarontansp
My usage is mainly is movies, gaming, tv show. which one will you pick?
projector pros: bigger screen at least 110inch , cheaper at >$1.5k
projector cons: noisy fans, the heat from the lamp, need a dark room or dim room
Tv pros: picture quality, room of any lighting
Tv cons: expensive, smaller screen
Projector mind the electric consumption and bulb change. High possiblity of tech failure than tv due to heat generated
Clearnfc
Projectors are too finicky - the lamps got life limit one, the lumens not bright enough to use in a lit room, must find a good spot to put the screen or if projecting onto a wall must make sure the wall surface is matt and ideally white etc.
Yes, with TS's budget, its best to get the biggest TV TS can afford.
Yueming
Plow98
TV video quality will always beat projector quality
One you are looking at a light source, the other only the reflected image from a light source.
Of course if marnee is a challenge, then "eating fish is better than no chicken" {as advised by our Yeendian ruler).
