iPhone 14/Plus/Pro/ProMax [No sales or flipping discussions]
Matrock5
Looks like a big dot. Did you spot it while checking the new phone?
Prob I held my the other phone to take a pic it is near but from the naked eye it is just a small little dot. I did not really saw it when I open my box to setup.
argentinafa
Tmr last day, still can return to Apple Store?
Sometimes, reason why I prefer those cases with suede lining inside is to prevent small dust & debris from entering.
For my 12PM last time when I tried PSAJ clear case, the occasional taking in & out the phone from the case to clear the accumulated dust stuck in-between the steel band and the case, also will cause minor hairline scratch.
Matrock5
Actually I’m not even sure what it is but based on my suspicions I reckon it could be a manufacturing issue or like what u said dust or debris. Mine is a Singtel set gotten it a day after launch day. Guess I will just live with it.
spidercyj
I realised that the AOD brightness is based on how bright your display was when in used.
example if you using at 50% brightness when you lock your screen it goes to like 5% but if you were at 25% then when lock it will become 1% or something
Matrock5
Got try to use ancient method????
Use saliva to wipe. :crazy: :eek:
Wah 😩 I tried using those screen cleaner with a micro fiber cloth. Honestly through the naked eye I cannot see this dot, and upon close examine again it looks like a perfect small circle dot. Sigh
hereiam7788
Prob for buying with telcos is that cannot exchange or return.
ragnarok95
Senior Moderator
Senior Moderator
Telco one only can exchange when you open and inspect. Once you walk out... it's your business liao.
szeli
if it’s too bright just enable auto dim in focus mode. it will become black screen with only clock n widgets showing
Tenpai
video was being disingenuous. never mention she dropped e phone. she only said it when ppl ask in e comments
Lol I dropped phone before but also never become like that thanks to tempered glass
For her phone to be so damaged, she must be dropping it from Mount Everest
