Matrock5
- Feb 23, 2017
Not really. Is not those u knock against it and gotten this dot and when you wipe u can feel it. This one like smooth.Not rough mean u can actually feel it?
Prob I held my the other phone to take a pic it is near but from the naked eye it is just a small little dot. I did not really saw it when I open my box to setup.Looks like a big dot. Did you spot it while checking the new phone?
Tmr last day, still can return to Apple Store?Prob I held my the other phone to take a pic it is near but from the naked eye it is just a small little dot. I did not really saw it when I open my box to setup.
Actually I’m not even sure what it is but based on my suspicions I reckon it could be a manufacturing issue or like what u said dust or debris. Mine is a Singtel set gotten it a day after launch day. Guess I will just live with it.Tmr last day, still can return to Apple Store?
Sometimes, reason why I prefer those cases with suede lining inside is to prevent small dust & debris from entering.
For my 12PM last time when I tried PSAJ clear case, the occasional taking in & out the phone from the case to clear the accumulated dust stuck in-between the steel band and the case, also will cause minor hairline scratch.
Got try to use ancient method????Not really. Is not those u knock against it and gotten this dot and when you wipe u can feel it. This one like smooth.
WahGot try to use ancient method????
Use saliva to wipe.![]()
Ya lor. Suck thumb. LolProb for buying with telcos is that cannot exchange or return.
Mine was delivery.Telco one only can exchange when you open and inspect. Once you walk out... it's your business liao.
if it’s too bright just enable auto dim in focus mode. it will become black screen with only clock n widgets showingI realised that the AOD brightness is based on how bright your display was when in used.
example if you using at 50% brightness when you lock your screen it goes to like 5% but if you were at 25% then when lock it will become 1% or something
u prob want to stay away from m1..Anyone tried MyRepublic and Circlelife e-sim? Seems quite reasonable priced.
Try if you can live with frustration from slow/no networkAnyone tried MyRepublic and Circlelife e-sim? Seems quite reasonable priced.
This one if fix, how much will it cost?
$800?++
video was being disingenuous. never mention she dropped e phone. she only said it when ppl ask in e commentsHow tf the phone can be damaged like that?
Lol I dropped phone before but also never become like that thanks to tempered glassvideo was being disingenuous. never mention she dropped e phone. she only said it when ppl ask in e comments
I am using MyRepublic eSIMAnyone tried MyRepublic and Circlelife e-sim? Seems quite reasonable priced.
