DIY PC Rig Recommendations For 2026
NightRaven49
hi all, its been a while since the pc rig recommendations thread was updated, so in continuing its spirit, i have put together a new list of recommendations with more modern parts. please note, ive only used local price lists; u may be able to find better deals elsewhere, but this list will focus on brand new local stock parts. for most builds i have also left out the prices of windows keys and case, these should be spent as deemed fit (assume $150 budget for case in total price if case not mentioned, recommendations at the bottom).
2026 UPDATE: ram and ssd costs are sky high, some of the lists below may no longer be accurate. unless u are able to source these for good prices, building now is generally not a good idea.
cheapest usable brand new rig, total: $525
i3-10100 + asrock h510-h2/m.2252techdeals
klevv / gskill / crucial ddr4-3200 8gb85bizgram
lexar nm620 256gb98techdeals
fsp hv pro 550w50pckaki
tecware nexus air m240tradepac
$500 pc, total: $466 see above
ryzen 5 5600g + asrock b550m wifi se279techdeals
gskill ripjaws v 2x 8gb 3600c18 ddr452tradepac
lexar nm620 512gb45vii pc
entry level 1440p gaming pc, total: $1263
ryzen 5 5600 + asrock b550m wifi se239techdeals
gskill ripjaws v 2x 8gb 3600c18 ddr4205pc themes
crucial e100 1tb199bizgram
sparkle arc b580 titan395dynacore
thermalright kg650w75dynacore
midrange gaming rig, total: $2356
ryzen 5 7500f + asus tuf gaming b650em-e wifi351dynacore
lexar ares rgb 2x 16gb 6000c30 ddr5569vii pc
thermalright phantom spirit 120 se v348dynacore
lexar nm790 1tb235vii pc
rx 9070 xt triple fan (model not specified, maybe asus prime?)899dynacore
deepcool pq850g104bizgram
for this build tier and higher u should consider adding additional case fans, personally recommend the arctic p12 @ $12 each from mr doraemon @t258jgn.
high performance productivity + gaming, total: $3733
core u7 270k plus + asus tuf gaming z890-plus wifi714dynacore
arctic liquid freezer iii 360mm147performance pc
wd black sn7100 1tb288techdeals
galax rtx 50801710bizgram
fsp vita gm 850w155bizgram
no compromise pc: well if u want a 285k/9950x3d2 + 5090, then u probably arent worrying about budget, just get whatever u want :s22: these are the 2 parts u should minimally go with:
lian li galahad 360 argb (if not doing custom watercooling)196tradepac
lian li sx1000p207tradepac
tecware flatline argbcheap, mesh intake, fits long gpus and tall coolers, preinstalled rgb fans52dynacore
cooler master mb311l argbbetter quality flatline78techdeals/bizgram
tecware fusiongood alternative to nr200 with support for cheaper non itx parts77techdeals
montech sky twogood airflow, 4 preinstalled argb fans with fan/rgb hub108bizgram
corsair 4000d airflowaffordable, spacious, good airflow118dynacore/techdeals
lian li lancool 216good thermal performance125viipc
lian li o11 mini air/dynamic minigreat looking case, very versatile
do note dynamic mini only accepts sfx psus
~150most sls shops
pricing correct as of 1 jun, though availability is not always guaranteed so if some parts go oos/change pricing please do sound off so i can update the relevant lists. i will also try to keep this updated as new hardware is released.
hopefully most bases have been covered, but if u have specific questions dont be afraid to ask. if u also have other recommendations that i missed out do feel free to add on :) happy building!
22 dec 22 - first revision
8 jan 23 - updated prices with non oos parts/8% gst, changed cheapest rig, revised price for work + gaming pc
6 feb 23 - revised prices and parts
15 apr 23 - revised prices and parts
18 may 23 - revised prices and parts
4 jun 23 - revised prices and parts
1 jul 23 - revised prices
6 aug 23 - revised prices and parts, renamed high end gaming rig to enthusiast
10 sep 23 - revised prices and parts
15 oct 23 - revised prices and parts
6 nov 23 - revised prices and parts
3 feb 24 - updated prices and parts with 9% gst, merged midrange reco into value reco
24 mar 24 - revised prices and parts
6 oct 24 - revised prices and parts
27 apr 25 - updated with 50/90 series
23 sep 25 - revised prices and parts
1 jun 26 - revised prices and parts
AhYoung
Thanks nightraven, it's been quite a few years without a proper guide for pc building.
rerear
Thanks for restarting this thread!
May I be the first?
Is this the right thread to post current rig for recommendations?
Motivation to upgrade:
  • Able to watch 4K movies/Youtube
  • Able to run Win 11
  • Prefer smaller form factor
There is no chance of selling off individually since parts are so old?
Want to recycle ssd/hdd, but not sure which other parts are able to be re-used e.g. RAM
The parts quoted above in the recommendations seems readily available in Carousell, is it usually safe to buy 2nd hand?
Win10 Pro
Gigabyte B150M-D3H
Intel Core i5-6500 3.20 Ghz 4 CPU
Gskills 4Gb x2 2400
Zotac NVIDIA Geforce GTX 960
Superflower Leadex 550W
LG 21:9 29UM68
CoolerMaster Silencio 452 Mini Tower
alphakim
My most expensive Intel 1st Gen 870 RIG $2,800 (2008) has died on me. It is time to start a new chapter (Intel 13th Gen i7 13700K - $3xxx) for me.
Good information for e newbie.
alphakim
hi all, its been a while since the pc rig recommendations thread was updated, so in continuing its spirit, i have put together a new list of recommendations with more modern parts. please note, ive only used local price lists + lazada/shopee; u may be able to find better deals elsewhere, but this list will focus on brand new local stock parts. for most builds i have also left out the prices of windows keys and case, these should be spent as deemed fit (assume $150 budget for case in total price if case not mentioned).
cheapest usable brand new rig, total: $495
ryzen 5 5600g + asus tuf gaming a520m plus wifi319dynacore
crucial 8gb 3200mhz cl2235dynacore/bizgram
lexar nm620 256gb38dynacore
fsp hv pro 550w58dynacore
tecware nexus air m245dynacore
strict 1k budget rig, total: $992
ryzen 5 5500 + asus tuf gaming a520m plus wifi297dynacore
klevv bolt x 2x 8gb 3600mhz ddr480dynacore
asus rx 6600 dual369infinity
value gaming pc, total: $1144
ryzen 5 5600 + asrock b550m pro4349dynacore
wd black sn770 500gb72dynacore
asus rx 6650 xt dual425vii pc
cooler master mwe 550w v2 bronze68pc themes
mid-range gaming rig, total: $1603
wd black sn770 1tb134dynacore
galax rtx 3070 ex 1 click oc785pc themes
cooler master mwe 650 v2 gold105dynacore
if strict 1.5k budget, alternative is going for galax rtx 3060 ti 1 click oc @ $598 from vii pc.
2k build, total: $1978
core i5-12400f + msi b660m mortar max wifi483dynacore
sapphire rx 6800 nitro+999bizgram
msi mpg a650gf132dynacore
high end gaming rig, total: $2575
ryzen 5 7600x + msi pro b650m-a wifi669dynacore
scythe fuma 2 rev b83dynacore
kingston fury beast black 2x 16gb 5200c40 ddr5 expo225dynacore
samsung 980 pro 1tb199fuwell/pc themes/vii pc
asus tuf gaming rx 6900 xt1099bizgram
msi mpg a750gf150dynacore
if budget up to 3k, can consider getting powercolor rx 7900 xt hellhound @ $1529 from bizgram/fuwell/vii pc.
high performance productivity + gaming, total: $4658
core i7-13700kf + asus prime z690-a980dynacore
arctic liquid freezer ii 360mm161dynacore
corsair vengeance 2x 16gb 5200c40 ddr5 OR
gigabyte aorus 2x 16gb 5200c40 ddr5
229dynacore
fuwell
sapphire rx 7900 xtx1699fuwell
no compromise pc: well if u want a 13900k/7950x + 4090, then u probably arent worrying about budget, just get whatever u want :) these are the 2 parts u should minimally go with:
msi mpg a850gf169dynacore
tecware flatline argbcheap, mesh intake, fits long gpus and tall coolers, preinstalled rgb fans54pc themes
cooler master mb311l argbbetter quality flatline75pc themes
tecware fusiongood alternative to nr200 with support for cheaper non itx parts82.50techdeals
corsair 4000d airflowaffordable, spacious, good airflow119dynacore/pc themes
lian li lancool 216good thermal performance135dynacore
lian li o11 mini air/dynamic minigreat looking case, very versatile~150bizgram/dynacore/fuwell/pc themes
pricing correct as of 22 dec, though availability is not always guaranteed so if some parts go oos/change pricing (eg the asus 6600 series promo is apparently for this month only) please do sound off so i can update the relevant lists. i will also try to keep this updated as new hardware is released.
Look like TS like AMD GPU 😀
rerear
Out of the components below, which ones are cheaper/more reliable and hence eaiser to buy from 2nd handers? And conversely, which ones are least-value/riskiest?
  1. Mobo
  2. CPU
  3. GPU
  4. PSU
  5. RAM
Phen8210
  1. Mobo
  2. CPU
  3. GPU
  4. PSU
  5. RAM
CPU and GPU are generally okay, buy them with a warranty left. GPU mining card avoid.
Used Mobo and PSU, I would avoid, too many things can go wrong.
For used ram, the most common thing is oxidization on the gold contacts, which you will need to take care of. Usually starts to happen after 6 months of usage, highly depending on the environment. Otherwise, your pc will be going on and off non-stop (memory training fail), and fail to boot, when you power it on.
BirdbrainZ
I have lost the use of my laptop recently, and am looking at a desktop replacement. I will be using it mainly for web browsing, Youtube, Twitch, and some light gaming, etc.
A couple of question please.
Will the Ryzen 5 5600g Vega 7 be sufficient to run Stalker Anomaly or the GAMMA mod if anyone has any experience with the game.
Can and is a better MB recommended for the Ryzen 5 5600g? I mean are b550 MB called for if I want to up the ram to 16gb?
Can and is it recommended to go 16gb ram?
rerear
is the 5600g rig that is recommended above, suitable to receive a GPU if so needed later on, or really that is not recommended and should stick with using the APU?
NightRaven49
Win10 Pro
Gigabyte B150M-D3H
Gskills 4Gb x2 2400
LG 21:9 29UM68
CoolerMaster Mini Tower (how to tell the model of my casing?)
in my experience is generally easier to sell as a whole unit compared to individual parts, especially for older parts like these. if the monitor is fine for ur use u should keep it, u could also keep the psu if u want, though the rest of the pc will be harder to sell.
i would suggest the cheapest rig in my recommendation and swap the case out for a tecware fusion, as mentioned it is about the same size as a nr200. u can also add on ram and a better psu if u want.
if u are comfortable with and understand the risks of 2nd hand, it is a viable alternative. so far ive had no issues with them, but remember to do ur due diligence like inspecting the parts or asking for tests before dealing.
are msi power supply good? usually last time buy seasonic or corsair
only their a-gf series, which is based off the same platform of other high end psu from cwt. it is just the cheapest high end psu available, no one is stopping u from getting more established units like corsair rm/x or seasonic focus as u mentioned ;)
i just chose the higher performing card at each price tier, most of which happen to be amd. may change once the asus dual deal ends and 8% gst kicks in.
  1. Mobo
  2. CPU
  3. GPU
  4. PSU
  5. RAM
i would say cpu and ram are generally safe to buy 2nd hand. cpus hardly ever die if used normally, and ram usually has lifetime warranty and is fairly small and light so even if have to ship overseas to rma it can be affordable to do so. the rest i would exercise more caution and get those with local warranty remaining.
ram capacity is not dependent on mobo chipset, 16gb of ram is doable on a520 or b550. in fact, with a 5600g, there is no point going b550 as the 5600g only supports pcie gen 3, so the main differentiating factor of b550 with gen 4 is nullified and it makes more sense going a520.
if ur budget allows go for it, though do get 2x 8gb sticks instead of 1x 16gb stick and make sure they are at least 3000c15.
as long as it is a modest gpu u should be fine, the 5600g shouldnt hold back any dgpu below the 3070.
BirdbrainZ
Can you recommend me a decently prized 16gb ram set that will suitably go with the 5600g please?
Yongkit
BirdbrainZ
this is fast 16GB kits for Ryzen system at reasonable price with delivery tomorrow without worry 8% GST next year, also with 1% off with PayNow settlement
Thanks you, but I was hoping of something that works relatively well enough, but still on the lower end of the price range.
These are the specs I am considering after the advise given here, and mix-matching the parts in the recommended builds list above.
CPU & MB: Ryzen 5 5600g + Asus tuf gaming a520m plus wifi ($319 dynacore)
Memory: 2 * Crucial 8gb 3200mhz cl22 ddr4 ($63 dynacore)
Storage: WD Black SN770 500gb ($72 dynacore)
PSU: FSP HV Pro 550w ($58 dynacore)
Case: Tecware Nexus Air m2 ($45 dynacore)
Total: $557 (a topup of $62 for double the storage and ram)
Are there any parts I should or can change to optimize the performance vs the dollar spent? Should I get faster ram, maybe a better case or PSU?
NightRaven49
Should I get faster ram, maybe a bette case or PSU?
u definitely need better ram than that if u want to game. yongkit's suggestion is actually quite relevant as it is high speed low latency, while these crucial ones are high latency so ur graphics performance will be adversely impacted. unfortunately can be quite difficult to find low latency kits locally, especially after crucial eol-ed their ballistix series with 3600c16. the only one i remember seeing was kingston's fury beast 3600c17 2x 8gb @ $95, also from dynacore. as for psu, if ur budget allows, wont hurt getting a better quality unit like the ones mentioned in the higher budget builds.
Yongkit
Are there any parts I should or can change to optimize the performance vs the dollar spent? Should I get faster ram, maybe a bette case or PSU?
I just added the less than $100 budget corsair lpx 16GB kits @ 3600CL16 which I feel the best bang for buck.
for Ryzen APU like 5600G you get better benefits with faster RAM kits like the 3600CL16 kits because of the igpu allocation for RAM.
Other than the RAM with this budget I would recommend slight top up go for 1TB storage (as actual storage 500GB nvme will be lesser by 10% scale) as you will fill up the space for game and storage with regular windows + game update patch if you do not maintain your storage on regular basis.
rerear
When selling desktop PC, is it safe to simply unplug HDD, SSD from the system, before sale? Or need to wipe something else from mobo and ram? E.g. reset Windows?
This mobo is mostly out of stock everywhere. Any other viable alternative for pairing with 5600g, is it worth to prepare for PCI 4.0?
