KleoZy
- Jan 1, 2000
me not so garang lol.. unless AIB spon, I dont mineIt's not content if it doesn't melt, make it melt.
Why not u suggest to view and verified at the seller’s place instead?Hi guys I’m currently using a 550w gold psu, am going to buy a 2nd hand 4080.
just wanna ask if it’s possible to just boot up my pc with the 4080 just to verify on gpuz on my 4080(not gonna boot any games)?
my 1000w psu is coming in a couple weeks, I just want to verify my purchase that’s all
It's an exceedingly power-efficient GPU. Based on my 4080 Gaming OC on a 1440p 240Hz monitor, under normal usage, during a boost the power usage is 40+W, streaming of youtube video is less than 20W and idle below 10W. Hence no issue just to verify.Hi guys I’m currently using a 550w gold psu, am going to buy a 2nd hand 4080.
Thinking to get either a 4080 or 4090 later this year. How's the issue with the power connector burning now?
For a period of time, there seems to be regular reports of the connectors burnt. But I dont come across these reports as frequent now.
I think it is not a widespread problem, and as per findings, it is due to users not connecting the connector properly. I believe this problem is uncommon with the RTX 4080 due to limited numbers sold (lower sample size) since inception, and lower power draw.Thinking to get either a 4080 or 4090 later this year. How's the issue with the power connector burning now?
The burning question for this card will be the cost. People are expecting this card to launch at 600 to 700 USD for performance between RTX 3080 Ti and 3080.
They need to collect enough defective 4070Ti dies before they can launch 4070 mah.wow, April then release? Why need a 3-month gap.. don't understand.
still need to lelong 3000 serieswow, April then release? Why need a 3-month gap.. don't understand.
I think this Hogwarts legacy will cause the price to go up, the outdoor really taxing, no joke. They should really consider removing denuvo man.
DLSS or FSR, you generally won't be able to tell the difference unless they are poorly optimized for the game. Having said that, given that DLSS is only available to Nvidia hardware, and it can also use FSR 2.0, so it does give Nvidia hardware an advantage because some games don't offer both upscaling methods. Also if you are also referring to the frame generation tech, I think there are reviews out there that concluded that it is useful when the game is running at high FPS, so that you get less visual issues, and also good latency.my 5700 XT recently uplorry, tempted to go nvidia leh
DLSS 3 like jin satki compared to FSR
