Getgo car accident
Alsonlow32
hi all, got into a bad accident while on a getgo car and a taxi driver crashed onto the back of my car. Can I ask whats the max damage payment if i never opt into CDW? I saw the website the excess fee is 10.8k, is that the max i have to pay? and will i get my license revoked? Thanks in advance
EJB
Should be $10K before G.
License won't revoke for RTAs unless you were speeding, but if you were, the taxi is too...
ZhuTou!
before G means? I wasnt speeding
I think he mean gst. For car insurance is split into 2 categories. One is 3rd party claim, one is OD aka own dmg. So the 10.8k is 5.4k each. 3rd party is the other car claim u for his dmg. OD is the cost of fixing ur car. So if it is 100% that guy fault, all cost pay by him. If 100% ur fault, u pay max 10.8k, covering his car dmg and ur car dmg. All these are done after investigation and sometimes waiting for the result may took mths.
But this type of ride sharing might be diff. They might ask u to pay upfront first before the result. So its better for u to consult getgo.
Alsonlow32
Thanks for your reply.
If found out that I'm not at fault, will the 10.8k be refunded back to me?
Or if found out both at fault, I won't be getting back the 10.8k?
So max is I pay 10.8k before gst if I'm at fault that's all?
Alsonlow32
By the way both getgo and the cab driver is under the same insurance company. If this information is useful
rizhal
Nothing to worry if you are rear ended by others.
it’s the other party responsibility.
natas
I was turning right at a discretionary right turn and the vehicle from the front sped and hit my rear while I was almost 80% completed my turn
Your story, 1 piece, 1 piece and confusing. :D Just prepare money....
ZhuTou!
Discretionary is the one without red arrow right? In such cases i would say its a 50/50 case. U might win or lose or 50/50, depends on ur video and the taxi video. If u lose totally, u have to pay the max 10.8k.
ZhuTou!
Yes if it is not ur fault, all will claim the other party. So u get ur money back or no need to pay anything.
sinistral
Just prepare at most 10.8k gone. Don't need to think too much. You won't win 100% of this case since you are partially at fault for not checking clear and safe before doing the right turn.
rizhal
Ok this one really 50/50 as the other party will give his own story to his advantage. Best wishes to you!
gnoes85
I tot taxi driver had the right of way.
And TS said taxi driver suddenly speed, quite bullshiat right.
EJB
You get back or not depends on the mercy of Getgo and it's TnCs.
Try reading it and see what it says.
EJB
Sounds like his fault too. Turning when knowing well that theres a car coming from the front. That's why I wish they will remove theses discretionary right turn and put a green arrow.
And increase travelling time as well as waiting time and also cause more jam.
