loganrunning
- May 12, 2017
a thought, if you are set on this.... since all in the 3-pack are all the same, you could try it out with 2 units (router + node). if ok, can keep the 3rd as spare, or sell.
reading this review it appears overkill (with it's 2 5GHz) given that you can use cable backhaul. But if both can be segregated for different devices (eg PCs vs NAS) that need to move large amounts of data, then it may suit your specific needs.
