- Sep 16, 2018
hi bro, got offered via 1688 on the same recontract plan of 1Gbps 8 month free @ 50.37, but will not provide new router from what CSO mentioned in call
i'm using singtel gigabit router ac elite + singtel ONT + singtel 4k tv box, wifi been slowing down a lot lately, 5ghz bandwidth can't even be received in same room as router
main consideration is want to maintain or reduce number of things that need to be powered
can ask for advice on the following:
1. whether i should take up this recontract or check other providers, eg myrepublic etc
2. should i get another router off carousell? mostly use wifi but require about at least 2~3 ethernet ports (ps4, tv, desktop)
3. should i consider the plan with wifi 6 router instead?
appreciate the advice!
1) I will say just go with this offer. Singtel Fibre is rather stable and you are using ONT. So you have many choices for router.
2) Yes. You can get Singtel Mesh Router at around S$20 (or even S$10) from Carousell which is a plug and play replacement/upgrade for your existing Singtel AC Elite. I will suggest you to get it first to see if you see improvement.
If not good enough, you can also get better ones like TP-Link Archer AX72 at around S$80. You can keep using Singtel Mesh Router as the main router but use Archer AX72 as an AP. You can also use Archer AX72 as the main router (you need to set up Singtel VLAN).
If you have higher budget, then there are many more choices.
3) No. The free Wifi 6 router or mesh node given is lousy. The cheap TP-Link Archer AX72 will be better than them.
