Which luggage is worth the money?
4getMePlz
Taka got luggage now until 12 or 14 May if I’m not wrong. Saw Eminent, Nat Geo, Caterpillar (CAT) luggage there. Was considering CAT stealth at $279. Any one got try Cat luggage before?
Hisashiburi
Only tried Lojel and Samsonite.
I think all luggages are more or less the same.
Try to get the lightest ones though.
Hisashiburi
Have a Lojel and Samsonite 25" luggage
After a few years, the Lojel lock stopped working...cant lock anymore.
Samsonite still ok, working fine.
ApeTruelove
Lojel cubo?? Anyway is better not to use the luggage lock because will give you a lot of trouble once damage especially when you are oversea
WarriorSG
I buy hardcase made of at least polycarbonate to make sure it last. From what I understand, Eminent and Hush Puppies are the same factory. Correct me if I'm wrong.
IcYFl4mEz
Anyone had issue with the airline check in baggage limit of total 158cm?
how many inch lugg to be safe?
beanstalk6
Moderator
Moderator
Weight limit is more applicable for check-in luggage while size applies for cabin luggage. What is your question?
Kfc2019
The sum of length, width and height of check in baggage must not exceed 158cm (62 inches)
So far , my 26-inch luggage suits my SQ flight very well.
But it is better to do your own measuring, due to differences manufacturers have their own sizes.
vinzphua
Many thanks to those who gave recommendations. For those looking for Lojel, Eminent and Hush Puppy, can find in Travel Store. Also a shout-out to Chester who works at the IMM outlet. Very helpful and knowledgeable.
