- May 15, 2000
Eminent is available at Mustafa, which is where I bought it.Hi Harky,
Thanks for yr reply.
Can I pls check, where can I find this Eminent luggage in SG? Thanks!
Thank u as well!Eminent is available at Mustafa, which is where I bought it.
Only tried Lojel and Samsonite.Taka got luggage now until 12 or 14 May if I’m not wrong. Saw Eminent, Nat Geo, Caterpillar (CAT) luggage there. Was considering CAT stealth at $279. Any one got try Cat luggage before?
I think all luggages are more or less the same.
Try to get the lightest ones though.
not sure now but most likely this weekend will haveAre there any luggage fairs now?
Lojel cubo?? Anyway is better not to use the luggage lock because will give you a lot of trouble once damage especially when you are overseaHave a Lojel and Samsonite 25" luggage
After a few years, the Lojel lock stopped working...cant lock anymore.
Samsonite still ok, working fine.
Not cubo i think.Lojel cubo?? Anyway is better not to use the luggage lock because will give you a lot of trouble once damage especially when you are oversea
Eminent is from Taiwan and Hush puppies is from US??I buy hardcase made of at least polycarbonate to make sure it last. From what I understand, Eminent and Hush Puppies are the same factory. Correct me if I'm wrong.
I highly doubt HP luggages are made in the US though.Eminent is from Taiwan and Hush puppies is from US??
Weight limit is more applicable for check-in luggage while size applies for cabin luggage. What is your question?Anyone had issue with the airline check in baggage limit of total 158cm?
how many inch lugg to be safe?
The sum of length, width and height of check in baggage must not exceed 158cm (62 inches)Anyone had issue with the airline check in baggage limit of total 158cm?
