Android TV Box
Philippng
thanks, but how do i find the root file/ know which is the root file?
in sendanywhere, you only tell sendanywhere you want to send app and selected all those app you want to transfer to the new box and over at the new box you received the apps and installed them.
Dont send system app as it may not be compatiable.
R6exR6
My SVIcloud 3 Pro feels worth the $228 I paid 2 years ago. Can't do without it's daily video feeds! 😘
rerear
SVIcloud 9, or Unblock Gen10 better?
Are both Google certified and able to Netflix 4K?
Where to buy in SG, or Taiwan?
Worthy upgrade from Mibox 4s?
rerear
what are the improvements over Mibox 4S, if any? Meaning unable to watch Netflix and Disney in 4K right?
Philippng
i am not sure if i am right most of all the box are not 4k ready although they claim to be. There are some video that open up the box and look into the chipset and confirm it to be, given the price of the box i tend to believe it is true.
gregory_choo
rerear
Trying to attach a NVME enclosure to the Mibox 4S (MDZ-22-AB), to use it as an external drive to play video files with VLC or Kodi. Can I confirm what kind of format does Mibox 4S take, can it work with either NTFS or exFAT? Seems my drive doesn't allow formatting in FAT32; it doesn't show up in Disk Management. It is a 1TB Crucial NVME M.2.
Also since the port behind the Mibox is only USB type-A, and my NVME enclosure is double-sided type-C, any good solution? Can I like, use a phone charger cable that has A-to-C USB?
albertlee
Can someone recommend a decent (not too costly) box to convert my TV into a "smart" one. Main requirements is video playback, especially x265 and youtube streaming.
Philippng
i think a google chromcast with google tv is good, however you need to be a little technical to be able to sideload app into the chromecast.
