Android TV Box
gregory_choo
Thanks.
Do you have any video I can watch to see how this is done?
I have absolutely no idea.
I just buy the SVIcloud box and watch everything from their pre-installed LUCA VOD app.
the money is yours, it is ok for you to waste $200+ more to buy an inferior box.
fyi, mibox is only $65.
gregory_choo
Thanks.
So I guess your "downloader" means it's either from Playstore or from "site: app.emotn.com".
no. downloader is an app.
if you are using downloader, you can install emotn store directly.
if you know how to manually install apps, you can go to emotn official site to get its apk file to installl emotn store.
limp_kopi
any recommended apps to download from XiaoMi MiBox playstore ?
(to watch movie)
Its seems that the Playstore doesn't have much apps.
(The seller shipped mine from HK to SG)
(Btw Disney+ says that it is not available in my region. Weird.)
gregory_choo
(to watch movie)
make sure that it is not china version.
the global version should have netflix button on the remote.
if you want free app, see my earlier post #4417
Philippng
Thanks.
check this out you should get a fairly good picture how to setup for google tv to sideload apk
After that get sendanywhere apk from sendanywhere official site for android and you are ready to receive app
from anywhere and anyone.
After that go to https://send-anywhere.com/
and installed the sendanywhere android version and then msg me i will send you the code for setting up iptv as well as vod.
limp_kopi
these are certified googleTV boxes, they come with premium vod apps such as netflix, disney+... etc
but if you want to use free vod apps, you can install yourself.
it is quite easy to do it.
1. install downloader from playstore.
2. start downloader, enter 96142 and press go.
3. press download button to download emotn store and install it.
4. open emotn, key in 202096 as share code.
there are about 40 vod / iptv apps. most are good, try some of them, delete those you don't like
not to install too many apps as your box will be slower, so uninstall those you dont need or dont use it often. e.g uninstall downloader after using it.
if you can't install emotn via step 1-3, download the apk file from the official site and install using thumbdrive.
site: app.emotn.com
Thanks Greg !
ridiculous?
the #4,417 some app force you upgrade then upgrade already force you login, we no login then cannot use liao.
:o
gregory_choo
:o
most dont need login.
some can log in by creating a random account, using fake email address.
there are 40+, you dont have to install all, 2 - 3 should be sufficient for most people.
CyberMew
My uncle ended up getting svi but it’s empty inside like a legit android box. Is it supposed to come with the lifetime live portion? If so what is the name and how to get it?
R6exR6
My Svicloud 3 Pro isn't totally empty. Has LUCA VOD, Youtube and a few other apps preinstalled. Never explore other apps. I only use LUCA VOD to watch all the free movies, dramas, animes, etc. these past 3 years.
Philippng
the last i use UB box, i will never get a tv box again. Since i have a smart tv google tv, I built my own iptv and is as good as any tv box can provide if not better.
I can now sideload my chinese iptv which come with live tv from HK TW SG and MY. As for VOD there are a few good one around Nivod and newfast are some of them.
Those with smart tv with google tv can try on your own
https://apkadmin.com/j1ab74v3zbng/DIYP影音带台标版_5.2.0.apk.html
Not advisable to be installed on handphone as it is from unknown source.
gregory_choo
what you said is you got an illegal android box.
gobrokepoker
could you share how to side load the chinese iptv on the DIYP app? I can't get it to work
Thanks in advance!
Philippng
Thanks in advance!
first you need to built a playlist and in txt format, m3u as ext to the file is also ok
eg myiptv.txt or myiptv.m3u
Then in the txt or m3u file the playlist go this way
eg
Movies,#genre# (Name of category,#genre#)
HBO,http://whateveriptv.com/hbo.m3u
History,http://whateveriptv.com/History.m3u (Name of the program,the URL)
Once you have the playlist up you can load to a website ( free webspace will do) or put the txt file in the folder of the app.
For free webspace you can check out this
https://cp1.awardspace.net/
For setup you can check out how to put the link into the app
Still facing problem pm me.
Goodluck and enjoy DIY
firestyle
lately i noticed that both of my mibox s will auto shut down overnight.
it doesn't behave that way last time...and i did not tingle with any of the power/sleep settings.
i have also tried going thru all the different settings and it dosn't seems to fix the problem.
does anyone here face the same problem as me?
Philippng
There could be several problem.
1 it could be over heated device.
2. there is a malware that automate the shut down
3. There could be a automate shutdown within your device which was schedule to shut down at a certain time.
If in the day time it didnot happen to shut down then the over heat issue may not be the cause.
it is probably a shedule time shutdown.
