Philippng
- Sep 14, 2021
Use sendanywherewhat is the most easier way to transfer all data (apps) inside android box A to android box B ?
ps: app/apk is not found in google play store
Use sendanywhere
in sendanywhere, you only tell sendanywhere you want to send app and selected all those app you want to transfer to the new box and over at the new box you received the apps and installed them.thanks, but how do i find the root file/ know which is the root file?
nvidia shield pro. buy from amazon.Hi guys what tv box recommended? Svicloud no worth hor
https://www.lazada.sg/shop/sg-svicl...fa5k6qxgJ&itemId=2834083118&channelSource=pdpSVIcloud 9, or Unblock Gen10 better?
Are both Google certified and able to Netflix 4K?
Where to buy in SG, or Taiwan?
Worthy upgrade from Mibox 4s?
both are not certified.SVIcloud 9, or Unblock Gen10 better?
i am not sure if i am right most of all the box are not 4k ready although they claim to be. There are some video that open up the box and look into the chipset and confirm it to be, given the price of the box i tend to believe it is true.what are the improvements over Mibox 4S, if any? Meaning unable to watch Netflix and Disney in 4K right?
mibox swhat are the improvements over Mibox 4S, if any? Meaning unable to watch Netflix and Disney in 4K right?
mibox 4s is china version, not google certified.
There's access to Google Play store, but must sign in Google account. Once done, I presume you can install Viu.can i install and run viu on the svicloud ?
Hi! Can share the app again?
https://apkadmin.com/j1ab74v3zbng/DIYP影音带台标版_5.2.0.apk.htmlHi! Can share the app again?
i think a google chromcast with google tv is good, however you need to be a little technical to be able to sideload app into the chromecast.Can someone recommend a decent (not too costly) box to convert my TV into a "smart" one. Main requirements is video playback, especially x265 and youtube streaming.
