crystalnox
- Feb 2, 2006
based on the results.dl ul
2.4 1 71.1 79.9
2 88.5 99.5
3 110.3 123
4 135.4 129.3
5 121 64.8
6 86.6 95.6
7 104.6 87.7
8 123.9 82.3
9 81.6 59
10 83.6 87
11 96.6 77
Try changing your 5Ghz channels and retest.
| dl | ul | ||
| 5ghz | auto | 197.3 | 165.3 |
36 | 210.3 | 222.3 | |
40 | 215.9 | 221.8 | |
44 | 214.6 | 223.7 | |
48 | 214.2 | 209.7 | |
149 | 204.5 | 208.3 | |
153 | 195 | 196.2 | |
157 | 206.9 | 219.6 | |
161 | 215.4 | 218.1 | |
165 | 201.1 | 198.3 | |
| dl | ul | ||
2.4ghz | 1 | 71.1 | 79.9 |
2 | 88.5 | 99.5 | |
3 | 110.3 | 123 | |
4 | 214.2 | 221 | |
5 | 121 | 64.8 | |
6 | 86.6 | 95.6 | |
7 | 104.6 | 87.7 | |
8 | 123.9 | 82.3 | |
9 | 81.6 | 59 | |
10 | 83.6 | 87 | |
11 | 96.6 | 77 |
Wah that is awfully low considering your router is 4T4R Wifi6. Try setting your channel width to 80Mhz, security set to WPA2/WPA3-Personal and OFDMA set to On in Advance settings.based on the results.
dl ul 5ghz auto 197.3 165.3 36 210.3 222.3 40 215.9 221.8 44 214.6 223.7 48 214.2 209.7 149 204.5 208.3 153 195 196.2 157 206.9 219.6 161 215.4 218.1 165 201.1 198.3
WPA3-Personal+WPA2-PSK[AES]Wah that is awfully low considering your router is 4T4R Wifi6. Try setting your channel width to 80Mhz, security set to WPA2/WPA3-Personal and OFDMA set to On in Advance settings.
Could it be you are connected to slow VPN? VPN can slow the speed considerably.WPA3-Personal+WPA2-PSK[AES]
2.4ghz + ofdma -
20hz- 164.3 , 117.9, 40hz, 106.2, 118
think its ok. the block is too congested probably
Not using vpn but I will try without Google dns again tmrCould it be you are connected to slow VPN? VPN can slow the speed considerably.
bro change your 5GHz channel width to 80MHz... Leave the 2.4GHz channel width at 20MHz. Enable OFDMA and TWT.
Thanks. Now dl is 521.9 and ul is 695. I picked 20/40/80/160hz max liaobro change your 5GHz channel width to 80MHz... Leave the 2.4GHz channel width at 20MHz. Enable OFDMA and TWT.
Your router by default was 20mhz (for 5GHz channel) out of the box?Thanks. Now dl is 521.9 and ul is 695. I picked 20/40/80/160hz max liao
550 up 592 down for 80hz. Can’t remb if 20 is defaultYour router by default was 20mhz (for 5GHz channel) out of the box?
Btw you can experiment with 20/40/80hz vs 20/40/80/160hz, sometimes leaving out 160hz can improve performance and range.
have to be default or you won't be getting ~200Mbps on speed tests.550 up 592 down for 80hz. Can’t remb if 20 is default
Try Speed Test with ethernet cableAny advise for a 500mbps user (contract expired for sometime) getting such speeds? Any possibility that M1 reduce the bandwidth because I'm not in contract with them? I have also drop them a DM and waiting for their response. - https://m1network.speedtestcustom.com/result/b38a7c90-6b4f-11ee-9c76-ed8a15fd295f
i alr tried all the channels. except width. see below based on 20mhz width then.The other thing is to try different channels or auto.
CH36/40/44/48 are often the most congested 5GHz channels.
I use CH60 (DFS channel) and 160Mhz channel bandwidth myself with my Asus RT-AX86U. This will not work for those who live near to the airport though.
Reference:
https://en.wikipedia.org/wiki/List_of_WLAN_channels
dl ul 5ghz auto 197.3 165.3 36 210.3 222.3 40 215.9 221.8 44 214.6 223.7 48 214.2 209.7 149 204.5 208.3 153 195 196.2 157 206.9 219.6 161 215.4 218.1 165 201.1 198.3dl ul 2.4ghz 1 71.1 79.9 2 88.5 99.5 3 110.3 123 4 214.2 221 5 121 64.8 6 86.6 95.6 7 104.6 87.7 8 123.9 82.3 9 81.6 59 10 83.6 87 11 96.6 77
Channel 60 @160MHz will still run into heavy traffic on the lower 36-48 channels the moment your client and router actually decides to communicate at 160MHz.The other thing is to try different channels or auto.
Reference:
