MyRepublic Mobile discussion thread
alvino
anyone using MR 5G (starhub), may i ask what happens if you're not in the area of the 5G Standalone coverage area? Does it go 4G at all, if so do you know if its starhub's 4G or M1's 4G network?
thinking to port in from zym.sg appreciate any replies
Arandalo
Fall back to StarHub 4G.
Cyborg
Whether 5G or 4G, it will be on Starhub platform.
Before porting over, it would be advisable to check with its phone compatability list with MYR 5G, else any issues encountered the staff will simply refers as incompatability device.
alvino
Yes thank you for the heads up! I read the past pages of some esim activation headaches. I’m on ip15pm. Should be fine. I’ll double check just in case too! Cheers and good day!
lexisnexus
Fall back to StarHub 4G, but please note you will see a quite significant downgrade from ZYM (Singtel network) regarding the coverage and download/upload speed.
alvino
Oh man really ah? Thanks for the heads up. I was hoping it’s better as I would like to hop on esim. I’m getting a bit poor speed during peak hours with Zym. Sometimes 5G only clocking 10-20mbps down on Speedtest. There were times with single digit download speed. Using ip15PM - only test speed with full reception bars
Arandalo
Interesting to hear that 5G speed also significantly throttled during peak hours. I guess Singtel network is truly overloaded, even with 5G. 4G network was already super congested from my experience.
alvino
yeah, i never had this issue previously with gomo's 5g(max at 900+mbps). zym is quite value for its bundled and not that its unusable. its just that im picky. I will jump to MR mobile to try on its next esim promo!
Lynxlok94
Honestly Zym is as good as it gets, and I am confident it will outperform Starhub/M1 or their MNVOs which may cost more for 5G access, unless ST really is that much more overpopulated and throttles a lot more than the other 2 in congested peak hours.
I only switched out because I could not make or receive calls at home, suspecting my area is a 3G deadspot for ST network.
If they ever introduce VoLTE, i'll port right back in.
curo
Just to check what is the experience of 5g on esim? Was thinking should I use esim with MR or go with giga and use sim card
phayze
You can use code to check on iphone whether is connected to NR/NSA/LTE/UTMS.
I had issue connecting to NR but was automatically solve after the telco had an outrage for 1/2 a day. Before the outrage, calling them many times and changing SIM card doesnt resolve the issue.
are you sure you using 5G? sometimes i see 5G icon but phone actually using 4G. on samsung the 5G icon doesn't have the white background, means its using 4G but showing 5G. on iphone no way to tell. I did a speed test, sure enough i was getting 4G speeds. Why is it like this i really don't know.
alvino
Confirm chop. I’m using iPhone 15 pro max for speed test, sometimes I toggle the 5G on and off too. If it’s results are bad I even airplane mode toggle or kill all apps reboot phone. Also I always make sure it’s full reception bar before I bother doing any speed test at all. Sometimes I even raise the phone in the air to speed test avoiding all crowd human obstacles haha
alvino
Care share the code to check?
Today gonna buy heya SIM card with the intention of porting out myrepubpic mobile number.
myrepublic contract is renewal on 6 November.
usually how long will it take my mrm to port out the number ? If I don’t renew on 6th number will my MyRepublic mobile number still be valid incase the heya port in didnt succeed
crystalnox
Should be enough time.
gaoqikai
For my experience on MR 5G (both eSIM and normal SIM), on iPhone 13 mini
Outdoor most area can get 5G SA. Speed will be from 300M to 1200M.
But, for same location, it is possible that today can connect to 5G, next day cannot, then later can. I suspect that MR is a bit de-prioritized by SH, and sometimes do not allow MR to use 5G at certain locations.
For indoors, I would say 1/3 of the time 5G SA, 1/3 5G NSA (on band 1), 1/3 of the time LTE. Speed all above 100M.
Overall very good
Cyborg
Understand that at Comex and IT Show, the MyR 5G standard plan of 90GB is now offered at $14.95 p/mth instead of $17.95 p/mth previously.
This offer seems like it is not advertised on media and not even on FB.
Care to confirm for those who had visited the Comex Fair?, TIA. (y)
rssd21
That is correct, it is only available at the tech show.
And $14.95 is only for first 3 months and will be $17.95 afterwards.
