Phen8210
- Jul 29, 2011
i should have the choice to disable E Cores and just leave P Cores on with HT right? like that shouldn't have issue.. machiam falling back to old skool intel.
just that a bit more troublesome la.. every time want to do work i need to tweak bios.. play game need to tweak bios..
edited: a quick google and i found some compatibility issues on vmware workstation with 12th/13th hybrid architecture.. but it seems like a software issue.. simple fix.. i firmly believe that the vmware bois will resolve those issues eventually..![]()
lol, it's not the application's fault. There's nothing for them to resolve.
Even games also have the same issue.
Hybrid architecture has existed since the 12th gen, but until now, such issues still arise now and then.
If you want consistency, better intel outside than inside.
