IHasChimken
- Nov 6, 2022
After the revert and reboot that SH have done, for me everything seems to be fine now. But too early to say haha
That's strange... I would have thought since MR leased their 10Gbps from SH, SH would prioritise their own customers first. My network seems to have stabilised, no more lag.Seems like Starhub was also affected but they kept quiet about it and refused to acknowledge any issue on their part when I called up to complain.
I'm also in the central/east area and I've been getting latency of up to 1000-3000ms and random disconnects on Starhub 10gbps plan starting Friday last week.
Speeds seem better today but still getting socket error when doing speedtest and up to 300ms ping.
For 10Gbps broadband in Sg, it seems like some users are stuck between a rock and a hard place (no-win situation) at the moment. You want stability go ST (and maybe SH but not so sure after the latest incident) but with ONR, you have little control over your home network. You want more control over your home network, go to MR with ONT but then stability becomes the problem...Well, today MR sucks! it was down the whole day until I restart the ONT just now. But the connection is so unstable I thought I'm using diap-up. uploading these 2 images--~170KB took nearly 10 minutes!
Its been exactly 4 weeks since the installation in 04 Oct, all I get was disappointment. This MR Hyperspeed is worst the SH 1Gbps or the MR 1Gbps I used in 2016.
Don't bother subscribing to MR 10Gbps if you care about stability, don't terminate your existing line too, have a backup. Can't imagine having no internet in this digital age.
Hopefully after the trial ends by Dec 2023, they both will have worked out most of the kinks and also upgrade the hardware (ONT) to support 10Gbps Wifi 7.I think MR and SH are new comers in the 10Gbps game, it is better to give them some time to see how it goes.
Wait for VQ to offer their 10G metro ethernet for the general public...For 10Gbps broadband in Sg, it seems like some users are stuck between a rock and a hard place (no-win situation) at the moment. You want stability go ST (and maybe SH but not so sure after the latest incident) but with ONR, you have little control over your home network. You want more control over your home network, go to MR with ONT but then stability becomes the problem...
Speaking of which, how is VQ's 10G performing so far?
Not bad. Most important thing is they left everything intact. Stability is not an issue so far and wired speeds as fast or a bit faster than SI. I suspect they switched the former SI 10Gbps customers over to their 10G metro ethernet (point-to-point) being offered on their corporate side. They also have point-to-multipoint which I suspect is XGS-PON. Claim to have 100Gbps core backbone network.Wait for VQ to offer their 10G metro ethernet for the general public...
Metro ethernet/Active optical ethernet (point-to-point) is definitely more expensive vs XGS-PON and costs more to scale up. MR 10Gbps monthly subscription is one-third of SI/VQ's.I thought VQ 10Gps plan kind of failed in the market already and the Metro Ethernet infrasture may be quite a bit more expensive than XGS-PON infrasture.
look at the upcoming maintainence list...MR 10Gbps is down again, and this time is different than before, I guess MR is trying to keep "surprising" me with their "service".
p.s. Somehow I can't see my spoiler text, is the forum blocking it?
THanks for the info but that doesn't explain why the issue always happen when I'm using the PC, which usually isn't midnight.look at the upcoming maintainence list...
https://myrepublic.net/sg/planned-maintenance-broadband-voice-services/
MR -- using ONT (XGS-PON ONT)Maybe this has already been shared in this thread but I am reluctant to read 33 pages of comments to find out so, my question is: MR's ONT connects to the supplied router through fiber or copper? If copper is by default, can I choose to use SPF+ fibre?
Could it be an ONT issue? Maybe get MR to come and check/replace?THanks for the info but that doesn't explain why the issue always happen when I'm using the PC, which usually isn't midnight.
Speaking of which, it was down the whole morning until I restart the ONT. the PoS is no better than a dialup modem, you can only pray and hope it will stay online.
Very likely but MR stated clearly they will charge me service visit if they "think" it wasn't ONT's fault. How am I gonna make the ONT go off line when they visit if the issue is intermittenly?Could it be an ONT issue? Maybe get MR to come and check/replace?
