- Sep 16, 2018
So MR is the only one using ONT? Anyone knows if i have my own asus router will they install for me? The AIMesh i can set up lah, just not very IT savvy so getting my main asus router to work with the ONT will be
Surely its not as simple as unplug their router, plug in my own router & viola without the need to reconfigure anything?
No, MR will only set up their 10G capable router.
Since MR is using ONT, indeed you can just plug your own router and then set up as per normal. You can set up AImesh so there is no issue here.
