- Sep 16, 2018
Yup, I did... I tried binding 2 ports and later all ports but still the same...
Try bridging only one port?
Just did 1 port, same... haiz... damn sianz liao... hahaTry bridging only one port?
Then no choice now.I just tried connecting to my Fortigate, also no IP... IPv6 also enabled...
Link status is up but DHCP failed...
1Gbps is on GPON, 10Gbps is using XGS-PON. Both can coexist on the same optical distribution network, but requires different gear because both operate on different wavelengths.By the way, do they provide the same ONT models as those in their 1Gbps plan?
Part of the reason they are doing it is probably because of the gahmen's 10Gbps masterplan.am I missing something here?
I think it's business driven; everyone have same config = easier to support.most ISPs are giving out ONR instead of ONT, which means we can't use our own router.
your guess is as good as mineWhat exactly is their target audience here?
Also, from this thread, it seems like most ISPs are giving out ONR instead of ONT, which means we can't use our own router.
What exactly is their target audience here? Is their target audience simply speedtest.com addicts, or am I missing something here?
In general, it can support all of the things a home user needed. Not a problem at all. Can use own router on bridge mode. Cheaper for 10Gbps Homehub+ so we signed. Also faster wifi speed. I think Soon MR will follow the rest la.@xiaofan @Mach3.2
I think people who consider 10Gbps might not be simply due to watching Netflix, Disney, or Prime TV at the same time. They can do that with a 1Gbps plan without issues.
I am unsure if there will be any hardware limitations because the ONT is not something we can replace or ask for an upgrade. It's not just about supporting the speed, but can it handle higher PPS?
Suppose someone is getting a 10Gbps with a mix of casual and somewhat real use cases like hosting server applications (non-mission-critical). In that case, I think it's safe to say that there will be higher PPS usage compared to the typical household/person usage.
That is right.ONR makes things much easier for the ISP in terms of support.
An ONR which combines both the modem and routing/DHCP function is alot easier for them to troubleshoot and resolve remotely, as most problems are caused by issue with routing, DHCP and DNS. They can always reboot/restart the whole device remotely as well
An ONT + 3rd party router setup is much more difficult to resolve without an onsite visit, as some of these issues can be caused by the 3rd party router which their tech support may not be familiar with (especially if its a brand not well known to them)
I think Starhub 10Gbps homehub is better deal as Wifi 7 is not commonly available in consumer laptop and usually wifi 6 only. Wifi 6 can give us 1.5Gbps on my laptop which is good.At least MR is using ONT.
For Starhub, the main audiences are for those who want a lot of contents. For them, 10Gbps bundle plan is actually cheaper than 1Gbps bundle plan. Then apparently you can bridge the Starhub Nokia ONR.
For Singtel 10Gbps plan, the audience is actually quite wide -- other than the power users who do not like ONR (1% of users, or at most 5% of the users).
Singtel is always good at marketing nearly-useless plans like 2Gbps. Now with the more powerful TP-Link HB810 WiFi 7 router (running in AP mode), I think they will be quite successful in convining quite some customers to upgrade.
1) 10Gps is always better than 1Gbps or 2Gbps.
2) Your WiFi no good -- no problem, get our mesh solution -- now we can offer WiFi 7 mesh (first HB810 is free, second one is also discounted)
Part of the reason they are doing it is probably because of the gahmen's 10Gbps masterplan.![]()
Moving to higher speed plans actually allow them to oversubscribe their backhual by a lot because as you pointed out, the baseline usage of normal residential homes are actually very low.
your guess is as good as mine![]()
Do not forget it is a home user plan.damm.. that sucks..i guess they only want the normies to subscribe lol
Honestly i have no problem using this plan. For work or business then should use business plan. My company using M1 for business plan. Some may use their home internet for business use but it is all up to the user.alright alright chill, 10Gbps is the best for home use ok, Better. Broader. Stronger. Enjoy ultra smooth streaming with HomeHub+ UltraSpeed that includes the fastest 10Gbps Broadband and unlimited entertainment from Premier League, Netflix Premium, Disney+, Amazon Prime and more!
Frankly I would be ok if they bundled the contents for 1gb plan. The price of epl, netflix and disney already 2/3 of the $88.77 promo price. It's like getting 10gbps for free@xiaofan @Mach3.2
Isn't Fasttrack and NAT connection offloading done on the CCR router?
So am I missing out on any HW offload features/optimisation by choosing the above combo.
I have also considered:
1) CCR2216-1G-12XS-2XQ - AIO but overkill for my setup
2) Edgerouter XG - concerned about long term support since cavium has been sold to marvel and UBNT has very limited updates/commitment to the Edgerouter product line.
Looking to mikrotik users and gurus for advise.
