- Sep 16, 2018
For those who do not plan to get 10G gears, but not willing to continue to recontract the 1Gbps plan from SingTel/M1/Starhub/MyRepublic/Viewquest, there is another good choice if SIMBA is available to you: to get WC 2.5Gbps + SIMBA 2.5Gbps plan. You pay only S$43.6 per month (GST included).
I do not recommend either WC 2.5Gbps plan (ONR, aggregated 2.5Gbps) or SIMBA 2.5Gbps plan (CGNAT, no digital voice if you need that, new player) if you just plan to get only one ISP. However, when you get both, you kind of sort out the limitations.
You can even use dual WAN Load Balance/Failover with a proper router and get redundancy and higher than 2Gbps wired speed as well as greater than 1Gbps wireless speed.
You can use routers like Asus RT-AX86U Pro, GT-AX6000 and Xiaomi BE7000. You can also use wired router like OpenWRT/pfSense using Intel N100 based mini PC with Quad 2.5G NICs plus cheap 2.5G APs like Asus TUF-AX4200, Xiaomi BE3600, etc.
