George Soros
- Aug 13, 2011
If go with ASRock, need to flash bios? I check pc part picker mention compatibility ?yea, prebuilts are generally better bang for buck these days.
i would spend an extra $100 or so for the upgrade from am4 to am5 (<1.5k for 7500f + 7800xt is still insanely hard to beat).
if u have pcie slots yes. but the phenom is so old it is unlikely to make use of any current gpu to its full potential.
i would go for asrock, it is generally cheaper with a similar feature set.
yes.
