3G SAINT
- Oct 30, 2011
Most are lowest floor but my frenz very lucky got sbf at punggol for 13th floor last time131 + 15= 142k for the lowest floor
WTF
WTF
If you like the location n within your budget, should try your luck, see can get or not.very tough call for me still...
location yes impt to me thats why i dun just go for bto without considering this factorif u get now, after 5 years MOP, u can rent out..... i think this 1 is the advantage ba.
dunnoe why u so urgent tho... since u mention location very important to chiu.....
my frd house very hot in the late afternoon.... sibei jialat.![]()
It depends, my first attempt in May 2021 when my number was called, only one unit left and it's 38sqm. Since I die die want 47sqm and all other units are taken up, by default it wasn't my fault that I couldn't pick one that day. So there's not much of option. So HDB waived the 1 year waiting period and I can proceed to apply for the next launch. So whatever unit is left, just go for it, price is not coming down at every launchooo SBF can choose.....
if SBF fail, consider second timer? or won't affect?
Maybe unit near to bin area or next to lift.do you know why ? both 47 sqm also
How long you go back homeaircon cannot too long nv switch on. you need to switch on at once every 2 to 3 week
If the block is completed, pay a visit and see yourself, could be corner unit or near lobby unitdo you know why ? both 47 sqm also
Wow. It's steep. This price is excluding 15k singles tax which will amount up to almost 200k.the flat with $182,800 is level 16
i think is still risky because before you apply for SBF you can already see the units , how many are 38 sqm and how many are 47 sqm. so maybe you have to be prepared that you will get 38 sqm in the end right?It depends, my first attempt in May 2021 when my number was called, only one unit left and it's 38sqm. Since I die die want 47sqm and all other units are taken up, by default it wasn't my fault that I couldn't pick one that day. So there's not much of option. So HDB waived the 1 year waiting period and I can proceed to apply for the next launch. So whatever unit is left, just go for it, price is not coming down at every launch
yea it is...Wow. It's steep. This price is excluding 15k singles tax which will amount up to almost 200k.
this 1 is very good idea... u should go and see....If the block is completed, pay a visit and see yourself, could be corner unit or near lobby unit
Resale?i have made my decision
To give a try for the sbfResale?
fast and furiousPaid $10 application fee. Let's see how it goes
It's because of the facing. I shall recommend you another lower floor at 11 flr 47sqm unit in another block. It's a better corner unit.do you know why ? both 47 sqm also
