winningeleven
No, your M1 2Gbps is using two LAN ports from the M1 ONT.
FTP can be connected to another ONT for Starhub.
Yes. My bad. U r right. Thank for correcting me.
Any ideas starhub fibre allowed user to use own router? For example . Mesh router from netgear orbi ?
Apparatus
Speedtest result from SH Trooper laptop at ONT
Ok or not?
Yes you can, but the cost may be high if you want 10G capable mesh, especially solutions from Netgear Orbi or Asus AImesh.
Cheapest way is still to get from Starhub the second unit of EB810v (S$15 per month x 24 month = S$360).
10Gbps plan bundle WiFi 7 routers -- real price will be below S$600 or lower from Carousell soon.
1) TP-Link HB810 -- Singtel (free first unit, second unit at S$16.80 per month x 24 month from Singtel) --> claimed by Singtel to be worth S$806.4.
(report says it does not work well in router mode, Singtel uses XGS-PON ONR and configure HB810 as AP).
2) TP-Link EB810V -- Starhub (free first unit, second unit at S$15 per month x 24 month from Starhub) --> worth S$720 (assume 50% discount)??
3) TP-Link Archer BE805 -- MyRepublic (S$50 top-up), claimed by MR to be worth S$799.
Apparatus
Die lah!
My SH 10Gbps totally collapsed. No output signal from the 10Gbps TP-LINK 8-port switch
I tried changing the ports and still no output signal from the switch
So I changed to TP-LINK 10Gbps 5-port switch and the result is the same
When the SH Trooper was present all the tests were ok
I think the switches need to update the firmware. Cannot be 2 switches also died mah because they were performing OK with my 1Gbps M1
Lexng88
One by one do testing starting router to one switch then one lan point first. I also using same TP-Link switch as yours. there no firmware on these switch.
maylyn
Die lah!
Check whether are you able to RMA if it’s still under warranty or not. Good luck 😉
Alternatively get the NetGear ones to try again, sorry no faith in TP-Link products IMO
Apparatus
Unmanaged switch cannot update firmware unlike managed switch
Apparatus
When I did speedtest using Ookla and at SH I got the following results for my 10Gbps. Can someone tell me where's the problem?
Is SH incoming so low speed?
I'm getting low speeds with my 10Gbps OWC ethernet adapter and TB4 Pro Dock. Cannot be both also so lousy, right? My LAN lines are CAT 6a and CAT 7 and my switches are 10Gbps
Any Windows 11 settings that need adjustment or inside TP Link website that needs updating? Router firmware just updated to the latest
TanKianW
You delete post, repost, new post, edit post.......Hard to keep track what exactly is your problem. One moment ONT 3 lights issue, one moment K** post to SH.
Maybe should stop your ganjiong spider, give SH a call instead of posting/reposting. Their ONT, their router, you got all the right ingredient to demand them to make it work for you liao.
Your best help is just a phone call away.​
eggy
Itchy hand cancelled the previous SH 10Gb appt, it was $88 with free Netflix etc. :D
Now considering the one you just shared -
SH 10Gb at $69.96
vs
MR 10gb (1 month free) $59.90 + one-time $50 for router :)
Oh, why did you cancel the $88 plan? it's a good deal.....
Apparatus
Only thing that makes me happy today is I can see WiFi 7 on my
ASUS Zenfone 10
and SAMSUNG S24U
