Sorry, can re- post the 10G server speed test link here? Let me try to do the speed test again.
https://resi10g.speedtest.starhub.com/10G
When i use this link to do the speed test, it asked me to down load the app to do the speed test and not using browser to test. I also getting 8.2 Gbps as my processor is not strong enough as i am using a laptop.
I actually feedback to Chrome and they actually updated the chrome browser. Now i can get 5+ Gbps.You should tell that guy in post #2290 here
https://forums.hardwarezone.com.sg/...el-starhub-myrepublic-and-vq.6930337/page-115
I checked. TP-Link Archer BE805 does not have speedtest function built in.Interesting that you mention that Singtel HB810 has SpeedTest function, where do you see the info? Thanks. I was under the impression that EB810v and HB810 are too customized so that they may lose quite some features of the normal Archer WiFi 7 routers like Archer BE800.
What about TP-Link Archer BE805 for MR users? -- hopefully MR BE805 users can chime in and reply.
As for VLAN 1091, it may still be useful for those who use Starhub TV+ Box -- probably more priority than if you do not use VLAN 1091. Not so sure about this.
When using the link i got 8.2 Gbps and it is using app too. Speed test.net app also 8.2 Gbps. When i use the updated chrome to go to speedtest.net to do speed test, i got 5+ Gbps. Earlier i got only 4.5 Gbps using chrome.@Henry Ng
So you are using the Starhub link and get 5+ Gbps using Chrome Browswe.
But if you use OOkla SpeedTest desktop app, you get 8.2Gbps, right?
I decided to get tx401. Gonna retire my sound blaster z
That is probably the way to go.
Once you get 10Gbps plan, eventually you will get at least one 10G cleint device.
Then you may get more 10G capable devices and may need a 10G switch.
Interestingly MR official Shopee store is also selling TP-Link TX401 but at a higher price of S$174 than other local distributors (around S$149), from a quick search (but I am not good at looking for lobangs).
https://shopee.sg/TP-Link-10Gbps-LAN-Card-PCI-E-Adapter-Network-Card-TX401-i.378475851.20791637608
https://forums.hardwarezone.com.sg/threads/tp-link-hb810-be22000-wifi-7-router-users.7003498/
I saw it from a screenshot here. But I haven't tried to set it to AP mode to see if I can get the same speedtest. I suspect not...
very nice router la.Thanks.
The HB810 built-in SpeedTest is actually very decent. By right the CPU in the EB810v should be the same as HB810 and then the speedtest result will be similar if there is such utility. Most like the CPU is the sae as Archer BE800 (Qualcomm Networking Pro 1220 ARM Cortex A73 quad-core processor at 2.2GHz, IPQ9574)
https://www.qualcomm.com/products/i...networking-device-finder/tp-link-archer-be800
https://www.qualcomm.com/products/i...networking-device-finder?Manufacturer=1725358
From the HB810 thread.
https://forums.hardwarezone.com.sg/...0-wifi-7-router-users.7003498/#post-151425327
Could be windows being weird again.Using Speedtest app with my TX401, I am getting only 3Gbps download but 7.5Gbps upload. Any idea why? I flashed the latest Marvell firmware already and updated drivers...
just need to restart everything and it will be ok.Using Speedtest app with my TX401, I am getting only 3Gbps download but 7.5Gbps upload. Any idea why? I flashed the latest Marvell firmware already and updated drivers...
See you want to buy from Amazon Japan for tx401 $91.07Can get for $128.14 from Shopee
https://shopee.sg/TP-LINK-TX401-PCI...98&xptdk=7daa20ca-1be7-4503-9348-1bc4461cb098
I'm also getting only about 4.8 download and 7.5 upload on my mac mini m2 pro with 10g ethernet. not sure why also.
Maybe live boot a linux distro and try the speedtest there?
@Apparatus had the same problem and he resolved it by reinstalling windows.
