Xiaomi Routers: Xiaomi BE10000/BE7000/BE6500 Pro/BE5000/BE3600, Xiaomi AX6000, Redmi AX6000, Redmi AX5400/Gaming, Xiaomi AX3200/AX3000, Xiaomi AX3000T
mantians
For Xiaomi routers that support dual WAN and port aggregation over 1G ports, any benefits to connect to 2 ports on the WC 2.5G plan ONR? Assuming the router in AP mode?
I believe the router has to be in router mode and not AP mode to get Dual WAN Load Balancing to work.
Benefits: > 1Gbps wired speed (from 2.5G LAN port) and wireless speed.
Reference: two successful stories (there are more such results, including using Xiaomi router)
https://forums.hardwarezone.com.sg/...dband-provider.5494964/page-92#post-151579135
https://forums.hardwarezone.com.sg/threads/simba-fibre-broadband.6883466/page-78#post-152486288
Xiamo BE5000 vs BE3600
Xiaomi BE5000 CPU AIROHA AN7563PT (Arm Cortex A53 dual core 1GHz CPU with NPU) is actually slower than BE3600 CPU IPQ5312 Arm Cortex A53 quad-core1.1GHz, with NPU). On the other hand, wireless performance of Xiaomi BE5000 is better than Xiaomi BE3600. It has also 512 MB RAM compared to Xiaomi BE3600's 128MB RAM.
Xiaomi routers are often quite cost effective
WiFi 7 router recommendations by 知电小春哥 for year 2024 6.18 sale
1. Below RMB 400
ZTE BE5100 Pro+ (512MB RAM, dual 2.5G ports) RMB 329
TP-Link TL-7DR5130 BE5100 (512MB RAM, single 2.5G port), RMB 321
Xiaomi BE3600 (256MB RAM, sing 2.5G port), RMB 199 (recommended to be used as AP or mesh node)
2. RMB 400 to RMB 700
Xiaomi BE6500 Pro
, 1GB RAM, quad 2.5G ports, RMB 649
ZTE BE7200 Pro+, 1GB RAM, dual 2.5G ports+ 3 x 1G ports, USB 3.0 port, RMB 579
JD Cloud BE6500, 1GB RAM, quad 2.5G ports, USB 3.0 port, RMB 599
Ruijie BE72 Pro, 1GB RAM, 5 x 2.5G ports and quad 1G ports, USB 3.0 port, RMB 699
TP-Link TL-7DR6560 BE6500, 1GB RAM, quad 2.5G ports, RMB 579
3. Above RMB 700
Xiaomi triband BE10000
, Qualcomm IPQ 9570 CPU, 2GB RAM, dual 10G ports (one of them is SFP+) + quad 2.5G ports, USB 3.0, RMB 1599
Asus RT-BE88U dual band BE7200, Broadcom BCM4916 CPU, 2GB RAM, dual 10G ports + quad 2.5G ports + quad 1G ports, USB 3.0, RMB 2199
WiFi 6 router recommendations by 知电小春哥 for year 2024 6.18 sale
1. RMB 300 and below
1) Xiaomi AX3000T, MTK Filogic 820 chipset, 256MB RAM, RMB 169, top pick
2) Ruijie 雪豹 X30E, MTK Filogic 820 chipset, 256MB RAM, RMB 169
3) ZTE 晴天 AX3000 墙面路由, ZTE CPU + MTK WiFi chipsets, 256MB RAM, RMB 189, nice form factor
Better but a bit more expensive than the above
4) Ruijie 黑豹 X30E, MTK Filogic 820 chipset, 256MB RAM, RMB 219
5) ZTE 巡天 AX3000 Pro+, ZTE CPU + MTK WiFi chipsets, 256MB RAM, 2.5G port, RMB 279
6) Ruijie X32 Pro, older MTK MT7622B chipset, 256MB RAM, RMB 299, good wireless coverage.
2. RMB 300 to RMB 600
1) 雷神X4 AX6000, Broadcom BCM68560 chipset, 512MB RAM, 2.5G port, RMB 379
2) Redmi AX6000, MTK Filogic 830 chipset, 512MB RAM, RMB 369, good WiFi signal
3) 磊科N60 AX6000, MTK Filogic 830 chipset, 256MB RAM, 2.5G port, RMB 449, not very good signal
4) TP-Link TL-XDR6078 AX6000, MTK Filogic 830 chipset, 512MB RAM, dual 2.5G ports, RMB 549
5) Ruijie天蝎 X60 NEW AX6000, MTK Filogic 830 chipset, 512MB RAM, dual 2.5G ports, RMB 599
3. RMB 600 to RMB 1200
1) Ruijie天蝎 X60 PRO V2, AX6000, MTK Filogic 830 chipset, 512MB RAM, 2.5G ports, RMB 699
2) TP-Link TL-XDR6088, AX6000, MTK Filogic 830 chipset, 512MB RAM, dual 2.5G ports, USB 3.0 port, RMB 899
3) Asus 天选路由TX-AX6000, AX6000, MTK Filogic 830 chipset, 512MB RAM, dual 2.5G ports, USB 3.0 port, RMB 1099 (offer price will be lower), top score in WiFi 6 router list
4) TP-Link TL-XTR8488 triband AX8400, MTK Filogic 830 chipset, 1GB RAM, dual 2.5G ports, USB 3.0 port, RMB 1159
4) > RMB 1200 flagship
Asus RT-AX89X, AX6000, Qualcomm IPQ8074 CPU, 1GB RAM, dual 10G ports (one is SFP+) plus 8 gigabit ports, USB 3.0 port, RMB 2199, best wifi signal among WiFI 6 router list
Asus ROG GT-AX11000 Pro triband, AX11000, Broadcom BCM4912 CPU, 1GB RAM, 10G port, 2.5G port, USB 3.0 port, RMB 3999
WiFi 6 router overall ranking by 知电小春哥
WiFi 7 ranking is not fully done yet. Here is the signal ranking
Some people may worry about Chinese UI of Xiaomi China routers, however you do not need to worry too much as you can use Google Translate.
The folllowing is from Xiaomi AX3000T Web UI using Google Translate Chrome Extension.
Xiaomi router lacks some features like OpenVPN/IPSec/Wireguard VPN support but it is probably good enough for average users.
A bit more details about some advanced settings: QoS VPN, DDNS
1) Xiaomi recommends NO QOS settings for typical Singapore Fibre internet plans (>>50Mbps)
Take note QoS settings will be disabled if you enable Dual WAN.
Note: I tried QoS settings and it does not seem to work with WiFi device speed limit settings. Maybe a FW bug.
2) VPN settings are useless -- no OpenVPN/IPsec/Wireguard support. The legacy PPTP/L2TP are not secure now.
3) DDNS -- you can use Dybdns and No-ip.
Adding a mesh node
More details for IPv6 settings
lowhenghao
Hi xiaofan, thanks for sharing the translated Web UI. Can I check if the ax3000t UI which u have shared was from a china variant of the router ? Do you know if the UI would be in English if say the router is bought from local xiaomi store?
The above is from China version of Xiaomi AX3000T.
As far as I know, local official Xiaomi Stores do not sell Xiaomi AX3000T global version (there is indeed a global version of Xiaomi AX3000T), only Xiaomi AX3000 (with internal antenna) which is totally different from Xiaomi AX3000T (with external antenna).
Local version of Xiaomi routers selling in official Xiaomi stores like Xiaomi AX3000, AX3200 and AX9000 (as well as the Xiaomi AX3600 global version sold last time) will have English UI.
BTW, occasionally local official Xiaomi stores (physical and online) will have limited stock of Xiaomi AX9000 triband router for sale at around S$249. I think it is still a very good buy, with top of the line Qualcomm IPQ8072 CPU and 1GB RAM, as well as 2.5G port and USB 3.0 port.
For example, when you need to form a mesh and you need to use wireless backhaul (no LAN ports in the rooms), you can buy two units to form Xiaomi mesh. It will be way better than cheaper triband mesh solution like TP-Link Deco X68 and X75.
I just checked and Xiaomi official Lazada and Shopee online stores have the stock.
Spec:
https://www.mi.com/global/product/mi-router-ax9000/specs
lowhenghao
Thx xiaofan. I have actually ordered ax3000t from Malaysia's lazada store for my parents place, will probably try it out tomorrow but am also worried that the 3 5G antenna won't be powerful enough. RM800 ish is quite a big investment I believe especially in Malaysia household. Thanks to your sharing I'm am now aware of Ruijie routers eg. X32pro / E5 / Ew3200gx pro with exceptional coverage but it's hard to find an international unit at 2nd hand.
Hmm, why so expensive at RM 800 (or S$229)?
Xiaomi AX3000T China version is at RMB229 before discount and around RMB165 after 6.18 discount, from official Xiaomi Taobao/Tmall Flagship store. Even with GST and shipping, it should still be much less than what you pay.
It is supposed to be cheaper than Xiaomi AX3000. Local version of Xiaomi AX3000 is selling at S$69 per piece from official Xiaomi stores.
lowhenghao
Sorry for the confusion, what I meant on the rm800 is for a new Xiaomi ax9000. I have actually bought ax3000t at RM135 ish.
Not so sure if anyone here got the Xiaomi BE3600/BE5000/BE6500 Pro/BE7000/BE10000, it will be good to hear the reviews.
I am getting the Xiaomi BE5000 from Taobao (RMB279+ shipment + GST) for testing purpose and it should reach here end of this month.
I have already got ZTE BE7200 Pro+ and I am using it as an AP after OpenWRT/pfSene virtual router.
Justbear
I got Xiaomi be5000 2 days ago. Still trying to setup to run the 2.5G from WC ONR.
I see. Thanks.
The easy way out is to set Xiaomi BE5000 as an AP (bridge mode) -- but you can use only 1Gbps then from Xiaomi BE5000.
You can try Dual WAN to see if it works for you or not. People have reported success with Xiaomi BE6500 Pro and BE7000.
The following is a simulated Dual WAN setup (as shown in the picture in the above post) as I have only Singel 1Gbps plan.
From the iperf3 results we can see that wireless speed can achieve > 1Gbps.
Wireless download -- 1.52 Gbps
Wireless upload -- 1.29 Gbps
pfSense virtual router (2.5G LAN) -- ZTE BE7200 Pro+ (2.5G WAN): to simulate WC 2.5Gbps plan
ZTE BE7200 Pro+ dual 1Gbps LAN -- Xiaomi AX3000T dual WAN (CH44, 160MHz) -- wireless client at close range
iperf3 server -- Linux LxC container (192.168.88.12)
iperf3 client -- Acer Windows 11 laptop with Intel AX201 wireless adapter
Bash:
PS C:\work\speedtest\iperf-3.16-win64> .\iperf3.exe -c 192.168.88.12 -R -P4
Connecting to host 192.168.88.12, port 5201
Reverse mode, remote host 192.168.88.12 is sending
[  5] local 192.168.31.125 port 9688 connected to 192.168.88.12 port 5201
[  7] local 192.168.31.125 port 9689 connected to 192.168.88.12 port 5201
[  9] local 192.168.31.125 port 9690 connected to 192.168.88.12 port 5201
[ 11] local 192.168.31.125 port 9691 connected to 192.168.88.12 port 5201
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.00   sec  38.8 MBytes   324 Mbits/sec
[  7]   0.00-1.00   sec  38.5 MBytes   322 Mbits/sec
[  9]   0.00-1.00   sec  88.5 MBytes   739 Mbits/sec
[ 11]   0.00-1.00   sec  13.6 MBytes   114 Mbits/sec
[SUM]   0.00-1.00   sec   179 MBytes  1.50 Gbits/sec
[  5]   1.00-2.00   sec  47.4 MBytes   397 Mbits/sec
[  7]   1.00-2.00   sec  33.9 MBytes   284 Mbits/sec
[  9]   1.00-2.00   sec  95.6 MBytes   802 Mbits/sec
[ 11]   1.00-2.00   sec  12.9 MBytes   108 Mbits/sec
[SUM]   1.00-2.00   sec   190 MBytes  1.59 Gbits/sec
[  5]   2.00-3.00   sec  44.4 MBytes   374 Mbits/sec
[  7]   2.00-3.00   sec  28.9 MBytes   243 Mbits/sec
[  9]   2.00-3.00   sec  94.8 MBytes   798 Mbits/sec
[ 11]   2.00-3.00   sec  12.6 MBytes   106 Mbits/sec
[SUM]   2.00-3.00   sec   181 MBytes  1.52 Gbits/sec
[  5]   3.00-4.00   sec  49.8 MBytes   417 Mbits/sec
[  7]   3.00-4.00   sec  31.5 MBytes   264 Mbits/sec
[  9]   3.00-4.00   sec  77.8 MBytes   651 Mbits/sec
[ 11]   3.00-4.00   sec  16.0 MBytes   134 Mbits/sec
[SUM]   3.00-4.00   sec   175 MBytes  1.47 Gbits/sec
[  5]   4.00-5.01   sec  49.0 MBytes   409 Mbits/sec
[  7]   4.00-5.01   sec  28.4 MBytes   237 Mbits/sec
[  9]   4.00-5.01   sec  97.4 MBytes   812 Mbits/sec
[ 11]   4.00-5.01   sec  13.5 MBytes   113 Mbits/sec
[SUM]   4.00-5.01   sec   188 MBytes  1.57 Gbits/sec
[  5]   5.01-6.00   sec  44.9 MBytes   378 Mbits/sec
[  7]   5.01-6.00   sec  26.1 MBytes   220 Mbits/sec
[  9]   5.01-6.00   sec  91.9 MBytes   775 Mbits/sec
[ 11]   5.01-6.00   sec  14.8 MBytes   124 Mbits/sec
[SUM]   5.01-6.00   sec   178 MBytes  1.50 Gbits/sec
[  5]   6.00-7.00   sec  44.0 MBytes   370 Mbits/sec
[  7]   6.00-7.00   sec  34.1 MBytes   287 Mbits/sec
[  9]   6.00-7.00   sec  89.6 MBytes   753 Mbits/sec
[ 11]   6.00-7.00   sec  19.5 MBytes   164 Mbits/sec
[SUM]   6.00-7.00   sec   187 MBytes  1.57 Gbits/sec
[  5]   7.00-8.01   sec  43.0 MBytes   358 Mbits/sec
[  7]   7.00-8.01   sec  33.8 MBytes   281 Mbits/sec
[  9]   7.00-8.01   sec  90.6 MBytes   755 Mbits/sec
[ 11]   7.00-8.01   sec  19.8 MBytes   164 Mbits/sec
[SUM]   7.00-8.01   sec   187 MBytes  1.56 Gbits/sec
[  5]   8.01-9.01   sec  38.1 MBytes   321 Mbits/sec
[  7]   8.01-9.01   sec  30.8 MBytes   259 Mbits/sec
[  9]   8.01-9.01   sec  83.8 MBytes   705 Mbits/sec
[ 11]   8.01-9.01   sec  18.5 MBytes   156 Mbits/sec
[SUM]   8.01-9.01   sec   171 MBytes  1.44 Gbits/sec
[  5]   9.01-10.00  sec  36.6 MBytes   308 Mbits/sec
[  7]   9.01-10.00  sec  30.2 MBytes   254 Mbits/sec
[  9]   9.01-10.00  sec  79.8 MBytes   670 Mbits/sec
[ 11]   9.01-10.00  sec  19.2 MBytes   162 Mbits/sec
[SUM]   9.01-10.00  sec   166 MBytes  1.39 Gbits/sec
[ ID] Interval           Transfer     Bitrate         Retr
[  5]   0.00-10.03  sec   439 MBytes   367 Mbits/sec    4             sender
[  5]   0.00-10.00  sec   436 MBytes   366 Mbits/sec                  receiver
[  7]   0.00-10.03  sec   320 MBytes   267 Mbits/sec    5             sender
[  7]   0.00-10.00  sec   316 MBytes   265 Mbits/sec                  receiver
[  9]   0.00-10.03  sec   892 MBytes   746 Mbits/sec  2158             sender
[  9]   0.00-10.00  sec   890 MBytes   746 Mbits/sec                  receiver
[ 11]   0.00-10.03  sec   163 MBytes   136 Mbits/sec    3             sender
[ 11]   0.00-10.00  sec   160 MBytes   134 Mbits/sec                  receiver
[SUM]   0.00-10.03  sec  1.77 GBytes  1.52 Gbits/sec  2170             sender
[SUM]   0.00-10.00  sec  1.76 GBytes  1.51 Gbits/sec                  receiver
iperf Done.
PS C:\work\speedtest\iperf-3.16-win64> .\iperf3.exe -c 192.168.88.12 -P4
[  5] local 192.168.31.125 port 9676 connected to 192.168.88.12 port 5201
[  7] local 192.168.31.125 port 9677 connected to 192.168.88.12 port 5201
[  9] local 192.168.31.125 port 9678 connected to 192.168.88.12 port 5201
[ 11] local 192.168.31.125 port 9679 connected to 192.168.88.12 port 5201
[  5]   0.00-1.00   sec  47.9 MBytes   401 Mbits/sec
[  7]   0.00-1.00   sec  23.4 MBytes   196 Mbits/sec
[  9]   0.00-1.00   sec  23.5 MBytes   197 Mbits/sec
[ 11]   0.00-1.00   sec  32.6 MBytes   273 Mbits/sec
[SUM]   0.00-1.00   sec   127 MBytes  1.07 Gbits/sec
[  5]   1.00-2.01   sec  45.5 MBytes   380 Mbits/sec
[  7]   1.00-2.01   sec  35.5 MBytes   297 Mbits/sec
[  9]   1.00-2.01   sec  33.2 MBytes   278 Mbits/sec
[ 11]   1.00-2.01   sec  31.1 MBytes   260 Mbits/sec
[SUM]   1.00-2.01   sec   145 MBytes  1.22 Gbits/sec
[  5]   2.01-3.01   sec  38.1 MBytes   319 Mbits/sec
[  7]   2.01-3.01   sec  51.8 MBytes   433 Mbits/sec
[  9]   2.01-3.01   sec  33.4 MBytes   279 Mbits/sec
[ 11]   2.01-3.01   sec  31.1 MBytes   260 Mbits/sec
[SUM]   2.01-3.01   sec   154 MBytes  1.29 Gbits/sec
[  5]   3.01-4.00   sec  43.5 MBytes   367 Mbits/sec
[  7]   3.01-4.00   sec  54.1 MBytes   457 Mbits/sec
[  9]   3.01-4.00   sec  36.5 MBytes   308 Mbits/sec
[ 11]   3.01-4.00   sec  25.5 MBytes   215 Mbits/sec
[SUM]   3.01-4.00   sec   160 MBytes  1.35 Gbits/sec
[  5]   4.00-5.01   sec  50.4 MBytes   421 Mbits/sec
[  7]   4.00-5.01   sec  44.9 MBytes   375 Mbits/sec
[  9]   4.00-5.01   sec  34.5 MBytes   289 Mbits/sec
[ 11]   4.00-5.01   sec  26.2 MBytes   220 Mbits/sec
[SUM]   4.00-5.01   sec   156 MBytes  1.30 Gbits/sec
[  5]   5.01-6.00   sec  46.1 MBytes   388 Mbits/sec
[  7]   5.01-6.00   sec  42.6 MBytes   359 Mbits/sec
[  9]   5.01-6.00   sec  29.5 MBytes   248 Mbits/sec
[ 11]   5.01-6.00   sec  34.1 MBytes   287 Mbits/sec
[SUM]   5.01-6.00   sec   152 MBytes  1.28 Gbits/sec
[  5]   6.00-7.01   sec  40.8 MBytes   340 Mbits/sec
[  7]   6.00-7.01   sec  54.5 MBytes   455 Mbits/sec
[  9]   6.00-7.01   sec  18.8 MBytes   156 Mbits/sec
[ 11]   6.00-7.01   sec  45.4 MBytes   378 Mbits/sec
[SUM]   6.00-7.01   sec   159 MBytes  1.33 Gbits/sec
[  5]   7.01-8.00   sec  33.6 MBytes   284 Mbits/sec
[  7]   7.01-8.00   sec  68.5 MBytes   578 Mbits/sec
[  9]   7.01-8.00   sec  18.9 MBytes   159 Mbits/sec
[ 11]   7.01-8.00   sec  42.1 MBytes   356 Mbits/sec
[SUM]   7.01-8.00   sec   163 MBytes  1.38 Gbits/sec
[  5]   8.00-9.01   sec  32.6 MBytes   271 Mbits/sec
[  7]   8.00-9.01   sec  58.8 MBytes   488 Mbits/sec
[  9]   8.00-9.01   sec  29.1 MBytes   242 Mbits/sec
[ 11]   8.00-9.01   sec  38.2 MBytes   318 Mbits/sec
[SUM]   8.00-9.01   sec   159 MBytes  1.32 Gbits/sec
[  5]   9.01-10.00  sec  32.0 MBytes   270 Mbits/sec
[  7]   9.01-10.00  sec  57.8 MBytes   488 Mbits/sec
[  9]   9.01-10.00  sec  36.5 MBytes   308 Mbits/sec
[ 11]   9.01-10.00  sec  33.6 MBytes   284 Mbits/sec
[SUM]   9.01-10.00  sec   160 MBytes  1.35 Gbits/sec
[  5]   0.00-10.00  sec   410 MBytes   344 Mbits/sec                  sender
[  5]   0.00-10.04  sec   409 MBytes   342 Mbits/sec                  receiver
[  7]   0.00-10.00  sec   492 MBytes   412 Mbits/sec                  sender
[  7]   0.00-10.04  sec   491 MBytes   411 Mbits/sec                  receiver
[  9]   0.00-10.00  sec   294 MBytes   246 Mbits/sec                  sender
[  9]   0.00-10.04  sec   293 MBytes   245 Mbits/sec                  receiver
[ 11]   0.00-10.00  sec   340 MBytes   285 Mbits/sec                  sender
[ 11]   0.00-10.04  sec   339 MBytes   283 Mbits/sec                  receiver
[SUM]   0.00-10.00  sec  1.50 GBytes  1.29 Gbits/sec                  sender
[SUM]   0.00-10.04  sec  1.50 GBytes  1.28 Gbits/sec                  receiver
iperf Done.
Xiaomi AX3000T stock firmware wireless Internet SpeedTest using OOkla Speedtest app.
Wireless settings: CH44, 160MHz channel bandwidth, 2.4GHz band disabled.
Wireless client: Acer Windows 11 laptop with Intel AX201 wireless adapter
The wireless performance is quite decent for such a low cost router.
1) very close at 30cm away
Bash:
PS C:\work\speedtest\ookla-speedtest-1.2.0-win64> .\speedtest.exe -s 13623
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.22 ms   (jitter: 0.31ms, low: 2.75ms, high: 3.63ms)
    Download:   758.16 Mbps (data used: 398.8 MB)
                  6.25 ms   (jitter: 2.84ms, low: 2.12ms, high: 14.38ms)
      Upload:   919.78 Mbps (data used: 1.2 GB)
                  8.39 ms   (jitter: 1.95ms, low: 4.76ms, high: 23.85ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/2960fea4-3f5d-4917-b707-b14127a19052
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.81 ms   (jitter: 1.94ms, low: 3.19ms, high: 10.80ms)
    Download:   748.28 Mbps (data used: 505.7 MB)
                  6.98 ms   (jitter: 2.61ms, low: 2.88ms, high: 20.04ms)
      Upload:   854.11 Mbps (data used: 850.1 MB)
                 11.32 ms   (jitter: 3.67ms, low: 5.24ms, high: 38.83ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/a2316124-e823-4994-8064-b6cb968fa403
2. 3m close range
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.53 ms   (jitter: 0.59ms, low: 2.94ms, high: 3.95ms)
    Download:   733.08 Mbps (data used: 700.6 MB)
                  7.35 ms   (jitter: 2.67ms, low: 3.30ms, high: 16.02ms)
      Upload:   738.53 Mbps (data used: 691.2 MB)
                 27.31 ms   (jitter: 11.77ms, low: 9.37ms, high: 313.59ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/cb55cf3b-4b18-4a54-a6c6-7aeed5ce4745
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.73 ms   (jitter: 0.75ms, low: 2.87ms, high: 4.01ms)
    Download:   708.38 Mbps (data used: 847.9 MB)
                  7.60 ms   (jitter: 5.97ms, low: 2.98ms, high: 240.54ms)
      Upload:   797.83 Mbps (data used: 1.1 GB)
                 20.37 ms   (jitter: 7.65ms, low: 3.47ms, high: 140.45ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/8261c118-1f67-4b58-8c78-cd7f05561801
3. One thick wall, 6m away (common toilet)
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.52 ms   (jitter: 0.39ms, low: 3.34ms, high: 4.18ms)
    Download:   449.95 Mbps (data used: 455.0 MB)
                 11.72 ms   (jitter: 9.11ms, low: 2.77ms, high: 40.76ms)
      Upload:   260.62 Mbps (data used: 365.1 MB)
                 68.98 ms   (jitter: 23.02ms, low: 10.88ms, high: 323.22ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/96cbb262-07fa-4507-939f-8f9da5e75cee
4. One more wall after the thick wall, 9m away (service yard)
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     2.87 ms   (jitter: 0.29ms, low: 2.74ms, high: 3.41ms)
    Download:   300.17 Mbps (data used: 495.0 MB)
                 15.98 ms   (jitter: 11.23ms, low: 3.08ms, high: 172.31ms)
      Upload:    78.79 Mbps (data used: 90.3 MB)
                219.20 ms   (jitter: 68.16ms, low: 11.15ms, high: 591.84ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/2f781cbb-4da3-4f4e-8d94-768b3c2cc024
Justbear
I see. Thanks.
Yup I tried that earlier, wifi still below 800 it seems (using mobile *not wifi7 to test)
