eD|t|0n
Anyone has any idea why M1 is so quiet on 5G/10G front?
Like totally no sound no nothing....machiam giving up the fight like that...
eD|t|0n
Yes SH uses XGS-PON ONT for 10Gbps plan. For 5Gbps plan it uses Nokia all-in-one ONR by default but you can request to change to ONT (better at the spot of sign-up).
MR 10Gbps plan uses XGS-PON ONT.
For ONT, you can use your preferred router to its full ability and no need to worry about Double NAT or things like that for ONR.
Starhub does not provide static IPv4 address, only dynamic. Same for Singtel, only dynamic IPv4 address.
MR provides static IPv4 address at one time charge of S$51. If you need static IPv4 address and 10Gbps, then MR is the only one to go now.
https://myrepublic.net/sg/static-ip/
Thanks for the summary. Very clear and concise. I will read up on MR t&c and see whether there is anything that needs clarification.
eD|t|0n
Trial Duration​
    • Customers who sign up for HyperSpeed 10Gbps or GAMER 10Gbps can enjoy the 10GPON trial, subject to MyRepublic’s discretion in determining the starting date of the 10GPON trial. The 10GPON trial is valid until 30 June 2024. However, MyRepublic reserves the right to, without any prior notice, modify, extend, suspend, or cease the 10GPON trial (in whole or in part) immediately and at any time, without further liability on MyRepublic to customers.
From MR website. the 10G is a "trial" version till end of this month only? Then still force ppl to sign 24months contract?
Henry Ng
Trial Duration​
Why still trial?
HiHelloBye
Trial Duration​
i'm also looking at this...
SH & ST made it clear that it's no longer a trial...
maybe just wait after 30 June 2024 and see what's next for MR...
Henry Ng
still okay, cat 5e internal cabling so bo bian, and main thing is for EPL 2 yrs :p
EPL for us only. Now UEPA EURO 2024, SH also do not have it included in their sports pass and we can not watch it. By right, SH should include it to Sports pass. Their sports pass is not complete la.
Yuup…make a better decision after Jun. maybe they extend trial to dec24…..
I am pretty sure MR 10Gbps will continue. Most likely they will extend the trial period, 10Gbps plan is the direction to go but I think they need to fulfill certain criteria set by the regulator (eg: IMDA) to be out of trial stage. If they can not meet the criteria, they may have to continue the tiral.
I guess there are much less subscribers of MR 10Gbps plan compared to Starhub 10Gbps subscribers. Many SH 10Gbps subscribers do not need 10Gbps at all, they subscribe just because of the contents bundle like Premier League for 24 mths.
Of course there is a chance that they will declare that the trial is over and the 10Gbps plan becomes a formal plan.
Heard that may be selling off the company to others.
I was sceptical about the news when it was first reported by The Edge Singapore.
https://www.theedgesingapore.com/news/ma/starhub-and-m1-potential-merger-said-be-back
I am still sceptical about the rumor even though there are more media reports about this matter. After all, Starhub CEO rebuffed the speculation as per the following Strait Times report.
https://www.straitstimes.com/busine...f-merger-with-m1-says-keen-on-boosting-profit
Henry Ng
I was sceptical about the news as it was first reported by Edge Singapore.
Nice to read this. I just hope that i TV contents can improve a bit like their Sports Pass, I think not good.
1) I am buying another cheap TB4 to 10G NIC at RMB 498, no idea how good it will be. The brand is GRIS, the chipset is AQC113.
【淘宝】https://m.tb.cn/h.g5bpbUA8DnyH6re?tk=XxtkWBmSjmh CZ8908 「GRIS USB4.0万兆网卡AQC113雷电4以太网88179A免驱动千兆RTL8156瑞昱8153B光纤Type-C3.1爱快esxi软路由8152B」
点击链接直接打开 或者 淘宝搜索直接打开
2) I have not received the previous purchase yet. It is at RMB 499.
Previous purchase is probably safer as there was a review on YouTube.
【淘宝】https://m.tb.cn/h.gU5jUNnTZZSGq6P?tk=uMb0WBm87P2 CZ0015 「乐扩 USB4网卡10G兼容雷电3/4单口万兆电口RJ45以太网适配器支持MAC」
gonnie
like to check something:
starhub 10g
The nokia ONT has 1x 10g and 3x lan out.
The starhub tech had connected the ONT 10g to the EB810V 10g WAN. And from the router distribute to the different lan points in the house (mbr,br2, br3, living room) via the 4 data points patch panel in the db box
But this router is too big for my DB box area and I am also concern on the heat issue.
Can I directly connect ONT to the 4 data points patch panel and relocate the router to the living room?
Or only 1 port can be used from the ONT?
thanks thanks~
starhub 10g
thanks thanks~
Only the 10G port can be used from the ONT.
There are a few ways to improve your situation.
1) Add a fan to resolve the heat issue
2) Put the router just outside of the DB Box by drilling a hole which can let six Ethernet cables go through.
ONT -- Ethernet cable -- EB810v outside of DB box
EB810v LAN ports -- Ethernet cables -- patch panel -- room LAN ports
3) Pull one more Ethernet cable to the living room and add a 10G or 2.5G switch in the DB box. If you already have two LAN ports close to each other, then no need to pull the extra cable.
FTP -- Living room LAN port 1 -- EB810v 10G WAN
Option 3A: more expensive but rooms have 10G access.
EB810v 10G LAN port -- Living room LAN port 2 -- patch panel -- 10G switch in DB box -- room LAN ports
Option 3B: cheaper but rooms have only 2.5G access
EB810v 2.5G LAN port -- Living room LAN port 2 -- patch panel -- 2.5G switch in DB box -- room LAN ports
EB810v 10G LAN port -- 10G capable desktop or NAS in the living room.
Henry Ng
starhub 10g
thanks thanks~
No la, the ONT must connect to Router first then from Router to the room. The router can be outside the box but the wiring must be there as mentioned earlier.
