Afternoon the compressor run at least 30% harder then at night base on my acI have dual aircon. The compressor is only for my bedroom 12k+9k+9k
What is ur setupAfternoon the compressor run at least 30% harder then at night base on my ac
If u plan to run afternoon, overcap is better then under cap
Any error codeMy 2 aircon in the 2 bedrooms stopped working today. Yesterday night they were still fine.
There are 2 compressors in the unit to the 2 fan coils in the 2 rooms. There are air coming out of both fan coils but they are not cold. One of the fan coil will auto-off after sometime. What can be the issues ? Any recommendations for repairs ? Thanks in advanced.
Still thinkingEnd of the day you convinced yourself to not change to Daikin (because spare parts expensive). lol
Afternoon at most i turn on 2x9k. The 12k only maybe once a week then will turn on all 3.Afternoon the compressor run at least 30% harder then at night base on my ac
Any error code
Don't need to think already.Still thinking
Agree fully. Even if it cost more. As long as space allows I will always always install single splits.MUY-GP13VF vs MXY-2H20VF = $69.25per yr = 10yr to break even (excluding inflation)
for my case system 2 MXY-2H20VF use far less power for it cost me $750 extra (system 1 12k is 1.4k and system 2 is 2.2k (one FCU)) and selecting MUY-GP13VF will cost me extra $70 in my bills per yr but to break even the $750, it take 10yr
i view AC not as lasting as in the old day. so i doubt my ac will be trouble free for 10yr and that another reason why i choose dual system 1 install in different yr
hope it helped @Jun Jun
aiyah. Let it go…. He just wants the attentionDon't need to think already.
Do what you want. Change or don't change, you already spammed a lot of jjww posts going in circles end up say due to spare part costs you don't want to change.
2compressors? Must be super old. The last I used 2 in one unit are sanyo compressors.My 2 aircon in the 2 bedrooms stopped working today. Yesterday night they were still fine.
less than 10 years ...2compressors? Must be super old. The last I used 2 in one unit are sanyo compressors.
ME brand…… your indoor blower got 2 green light indicators. If that 2 green light blinking, that likely mean your PCB uplorry leow.Can check where to get error code ? They are mitsubishi electric starmex.
MUY-GP13VF / MSY-GP13VFWhat is ur setup
bro, only $60 not extra $750 like mine.Afternoon at most i turn on 2x9k. The 12k only maybe once a week then will turn on all 3.
Around 30 minutes.......Could I check, do you remember how long did your installer vacuum the new condenser for?
