condensate pump is like thisHi all, wanted to install system 4 aircon (adding aircon in living room) while current is system 3 aircon.
Installer came to site visit and say need to install condensate pump as the living room aircon will be lower than the one in all the rooms.
They are charging $250 for the condensate pump. May I know if this price is reasonable and does anyone have image of how your condensate pump and how the piping connecting to the condensate look like after installation?
Hi @The_King , thank you for the image. how does the electricity run for this pump? is it connected to the aircon electricity or there's an separate 3 pin plug to power this pump in the room that it is installed?condensate pump is like this
No idea, it hidden behind the trunking but trunking connected to fcuHi @The_King , thank you for the image. how does the electricity run for this pump? is it connected to the aircon electricity or there's an separate 3 pin plug to power this pump in the room that it is installed?
Thanks for your suggestion. I am thinking of getting 2nd opinion.close door and window , single button powerful mode, I guess within 5mins auto off back to normal setting.
If still could not get within 5 hours, should be low gas pressure.
My master bedroom set on 26c with far bar 1.
No powerful mode. Sometime take 2 to 3 hours then light off.
If turn on turbo model , I think around 30-1 hours light off.
For common room 30mins light off, not need use powerful mode.
i prefer you call them back and check gas pressure got a little bit help
I read about the removal of current limiter in this thread. This is my 1st time hearing such. Is this a common practice?remove current limiter. also which f the 3 are on? 10 or 13 or 18 or all? if all then no way to hit 22c. maybe at night after a couple of hours. if 10 then the room is small and should be able to get 22.
Powerful mode = high fan with timer.Thanks for your suggestion. I am thinking of getting 2nd opinion.
Sorry, I'm not sure what 'single button powerful mode' is. I thought just 1 power ON/OFF button?
Curious, why do you not use higher fan speed? I thought that will cool room faster too.
Not only high fan with timer. But max cooling.Powerful mode = high fan with timer.
where you get this thing from newly installed?
Some extended need you to service your ac from authorized agent else they can void your warranty. Do check it.Hi All,
My installation of ME Starmex System 4 installation is tomorrow from Harvey Norman. The installation contractor is *Easycool Aircon Servicing*. Please advise is it worth buying the extended warrant from HN? Is it also good to have yearly service plan with service contractors or do adhoc services as and when needed.
Is it good to do a regular service such as quarterly or half-yearly?
Thanks for advise.
Don’t want the drain pump, make the look uglySome extended need you to service your ac from authorized agent else they can void your warranty. Do check it.
If u dont mind can diy a bit, it will save your money, and if money not important then get someone to clean every 3 to 4 month depend on how often u use your ac
My friend install cause too many build in.Don’t want the drain pump, make the look ugly
I saw the thing in FB aircon Malaysia group. Whose knows sg got ppl installed
Weather hot la.Hi all, may i know what is the power consumption for a 9k + 12k fancoil with 4H33VG compressor running at 24c low fan speed?
Just change my aircon 1 month ago, realise today from sp app that the power consumption increased a lot compared to when just installed.
Any kind soul can help to explain?
Last night heavy rain leh.Weather hot la.
