ViewQwest Fiber Broadband Official Thread - Part 6
shachok86
for recon is 12 mth discounted price ..$18.98/mth then $44.98/mth.... 3gbps better than paying current 1gbps without contract like mine...but all the asus router available is lousy..like clearing old stock and promoting amazon eero router... also i cant find any option to addon static ip when i try to recon
abstrax
I just recon their 3Gbps plan too. Check with their tech support that can use back old 1Gbps router.
yosemi
yea look cheaper also, mine also no contract de
TopGun
Anyone tried their 3Gbps SFP+ Module bundle at $20.98?
I have a UDM Pro SE and I wonder if it's a simply plug and play.
Currently w/o contract and paying about the same price so while I have no use for the 3Gbps, the SPF+ setup and slightly lower price is enticing.
Mach3.2
Just placed an order for it. Hopefully it'd just work on my Aruba InstantOn switch or I'm going to have a problem.. 🤣
SKinny86
Based on the responses here it seems either bridged ONR to router or opt for SPF+ module to an SPF+ supported router.
for 3Gbps plan, what's the speed of the ethernet port @ bridged ONR ? 10Gbps?
for the digital phone, do they support port-in?
ltr 3gb plan the onr they give is 1gbps de ?
From what I read, the bridged XGS-PON ONR is the same for 3Gbps/5Gbps/10Gbps plan. So you will have single 2.5G/5G/10G compatible port.
No idea if you can port over your existing digital voice number or not. Most likely not.
VQ seems to have its own OneVoice service.
https://viewqwest.com/sg/residential/onevoice/
VQ network setup for XGS-PON based 3Gbps/5Gbps/10Gbps plan, using eero Max 7 as the example router.
https://viewqwest.com/sg/residential/xgspon/
XiaoFu99
My guess, since all plans are using the same bridged ONR, so it has to cater to the highest possible speed which is 10Gbps. Looks like pretty good deal (3Gbps+Voice @ $25+) for been faster and cheaper than M1 500Mbps @ ~$31.
Oh btw, does VQ comes with CGNAT or the typical dynamic IP?
CGNAT.
You may have to pay for static IPv4 add-on at S$4.03 per month (more expensive than MR one time charge of S$51).
https://viewqwest.com/sg/residential/faq/static-ip/
