acertey
Hi was looking to upgrade my system. Was primary using a AMD Ryzen 5 5600X with Hellhound 6700XT.
I was looking at the below specs, and was thinking if it is a worthwhile upgrade.
Will be great if someone can introduce replacement for the following:
1. RAM - seems all is expensive, and actually does 16gb vs 32gb makes a huge diff?
2. For SSD - any recommendations for 500GB? Mainly i use it for OS, storage i can go for the 2TB 3.5 inch
3. PSU - i think 750w should be enough, what is a full modular reliable brand now adays you guys use?
Any advise is much appreciated.
Processor - Ryzen5 7600
Motherboard - ASUS TUF GAMING B650-E WIFI
513​
RAM - CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6400MHz CL32
156.21​
Storage - Samsung 980 Pro 7000MB/s Gen4 Nvme M.2 1TB
127.8​
HDD 3.5 Inch 2TB
100​
Superflower Leadex III 850W ‐ 80PLUS Gold Full Modular PCIe 5.0
149​
Powercolor Hellhound Amd Radeon RX 7800XT 16GB OC Triple Fan GDDR6
750​
Be Quiet Case
113​
Corsair iCUE H100
124​
NightRaven49
the 5600x + 6700xt is still quite a capable gaming setup. the 7600 + 7800xt does provide up to a 50% uplift, though id only go for it if the current setup is really struggling.
ddr4 is actually dirt cheap now. capacity does matter, especially in more demanding games.
ddr5 16gb isnt that much cheaper than 32gb, so u might as well get 32gb.
156.21​
some of these look like amazon prices. in that case, u may be better served by the teamgroup tcreate kit for $145. sure it is slower 6000c30, but ur still getting 10ns cas latency and u will likely not notice the difference; am5 sees marginal gains above 6000mhz ram. id stay away from corsair ram either way.
513​
dynacore offers local set bundle for 488. even if its the only thing u buy from them and incur the $15 extra, total is still 503 (513 is a miscalc?). but u can get something to avoid this $15 fee:
Corsair iCUE H100
124​
the h100 is terrible on am5.
u can get the arctic liquid freezer iii 240, which is a much better performing aio, from dynacore for cheaper than this h100. so total u spend 488 + 118 = 606 (avoiding the $15), saving $30 from ur original 513 + 124 = 637 spend, and u get a much cooler and quieter system. the only caveat is the case u get has to be able to accommodate the thicker rad, but most full size cases should be able to do so comfortably.
127.8​
the wd black sn850x is very comparable but costs $115.
149​
even 650w is enough. but i would go for the adata xpg core reactor 750w from performance pc for $125 with 10y local warranty vs superflower 5y, if they still have it in stock. even the 850w core reactor is still cheaper than this.
however, even with all these cost savings, the total build is still running very close to 2k. if u dont mind prebuilt, invaderpc offers a basic 7600 + 7800xt system for 1.35k with quite a range of upgrade options. with team tforce 6000c30 ram, rm750e psu, lian li galahad trinity aio and t500 nvme upgrade, its 1.7k. then u diy add a decent 3.5" nas hdd for about $120 (invader doesnt list which specific models are being used for hdd addon so best to avoid), overall save around $150 with all local parts, the convenience of home delivery and 1y onsite warranty. u have to contend with some parts being different from ur original plan (eg gpu, case), though u can message them to see if they can do up a custom build.
acertey
Thanks bro for the reply, deeply appreciated. Actually for DDR4 vs DDR5 any major differences in performance? I was looking to get RAM locally also if the price is right. Seems so far Team T-Force DDR5 6000mhz 32Gb CL30 is best bet
NightRaven49
am5 only supports ddr5.
media mart sells the adata xpg lancer blade rgb 2x 16gb 6000c30 for 155. if ok with extra 2 clock cycles worth of cas latency, performance pc sells the klevv fit v 2x 16gb 6000c32 for 131. but buying ram from overseas still not a bad idea, as it is quite light and cheap to ship back if need to claim warranty.
acertey
thanks bro, saw amazon G Skill Trident Z5 Neo, C30 for 165 before shipping, and online i found Teamgroup T-Force Delta C30 $165. Klevv looks like a good choice also
BookieX
Heya, back again for another green light on rig purchase!
Last year y'all recommended me the 4070 7500f build from invaderpc and it's a really great purchase which I really appreciate and thank you guys for that. I'm back for another recommendation but this time it's for my spouse
Am looking to get a similar rig for her to game with me and seems like there's no longer the 4070 7500f build and the closest is the MASTER M15 | RX 7800XT | Ryzen 5 7600 build from invaderpc @ $1,349
What's the upgrade I should go for this time, I remember y'all recommended to up the PSU and to 32GB ram so
- G.SKILL FLARE X5 DDR5 32GB CL36 for $77? or M5 for $87
- Which model of PSU to go for? and 750W or 850W?
Is this the set-up the best purchase value wise?
Aftershock do have a 4070 7600 but at $1,475 which is +$126 more, not sure if it's worth it.
Just incase she feel like it's an overkill for her usage and don't want us to spend too much, I'm guessing the MASTER M03 | RTX 4060 | Ryzen 5 5600 is best budget option?
Same thing to go for 32GB ram and 750W for this option?
If you guys have to pick, better to just purchase it immediately or wait for 10.10 sale or 11.11/black friday?
demonkyo
Hi all
I'm looking to get a desktop, its main purpose is for watching 4K movies, no hardcore gaming.
If possible I want to explore desktop VR gaming with my Pico 4, it is not a priority if this require very high end and expensive parts.
What are the min spec for CUP and GPU that should be considered for this setup?
My days of going down to SL to collect parts and build them are over lol, I am looking at getting ready made from Invader, if know of suitable builds can recommend them?
sacar101
Hi All, unfortunately I have not build my replacement PC yet and I have changed some of the parts (from an SFF to a m-ATX case). Mainly because I lazy to measure... 🙃
All the prices (except RAM) are from Dynacore:
CPU + MBASUS TUF GAMING B650M-E WIFI + 7800X3D
759​
CPU CoolerThermalright Phantom Spirit 120 SE
52​
GPUGigabyte RTX4070Ti Super Gaming
1275​
RAMTEAMGROUP T-Create Expert DDR5 48GB Kit 6400MHz CL32 (Amazon)
223​
SSDWD Black SN850X 2TB
225​
PSUCorsair SF750-750W
249​
CaseLIAN LI DAN M-ATX A3
110​
Case FanPhanteks T30 120MM PWM X 3
110​
MonitorAOC 27"Q27G3XMN
458​
I'm open with any suggestion and advise, especially for monitor. Thank you!
NightRaven49
for ram, id go for the teamgroup tforce delta 6000mhz cl30 kit, it is cheaper, has lower latency and rgb. for psu, 750w is plenty, and most of the upgrades on offer are pretty good options.
depends on what u consider value. for pure performance per dollar in gpu heavy games, 5600 + 7800xt builds for under 1.2k are best. if u want to factor in the performance uplift and upgradability of am5, then sure these 7600 + 7800xt builds would be good, though now 5600 + 4060 builds also become quite competitive in performance per dollar. imo, ponying up the ~$150 for am5 is worth it as the 7600 is quite a bit faster and u have the option for a drop in upgrade years down the road, while the only upgrade options from the 5600 are the am4 x3d cpus which can only match the 7600.
unless ur spouse plays heavy rt games or places importance on dlss, then probably not. also cannot tell if these are the slightly gimped gddr6 4070s either, which are slightly slower than the original gddr6x versions, and which even 7700xts can almost match.
yes on ram, though 650w is already enough. the upgrade to the cooler master mwe v2 for less than $50 would be ideal. for under 1k, this build would be unbeatable.
vr gaming is very intensive, with ur pico 4 having to display 2160p x 2160p * 2 eyes at high enough refresh rates to be immersive. quite the opposite end of the spectrum from just watching movies and no gaming :s13:
for just videos, even mini pcs with integrated graphics will do fine, u can get 5560u pcs for much less than $500 these days. if u prefer desktop like from invader, their cheapest ready to ship with the 5600g is basically the same thing, though u get desktop grade parts and some upgradability (eg being able to add on dgpu later). if u want to do vr gaming, minimum i would go with is maybe something with a 7700xt, which will be at least double the price of the aforementioned 5600g build.
249​
110​
the a3-matx is able to take in atx power supplies which are a lot cheaper. if the adata xpg core reactor 750w is still available at 125 from performance pc (half the price of the sf750!), thats a much better buy.
sacar101
Will atx psu blocks the airflow? I trying to get as much airflow as possible which is why I choose sfx.
The psu you recommended has sold out. The best I found is adata xpg core reactor ii 750w @ 139.
demonkyo
Lol this one is bonus if can, I thought specs for watching 4K movies needs to be high too in the same realm.
I have no idea it is so affordable now to fulfill my requirement, the last time I build my own, the parts need latest and expensive GPU to go 4K.
Thanks for the advice.
NightRaven49
the front panel of the a3-matx is solid, so there is no airflow to speak of from the front and thus the size of the psu doesnt matter all that much. i would think having a sfx psu is for the space for top mounting 360mm aio.
dynacore offers it for 129, which is still pretty decent. if u dont mind using the pcie 6+2p to 12vhpwr adaptor, get a couple years more warranty and save another $10 dynacore also offers the cooler master v650 v2 gold, though u might need to disable the hybrid mode for it to not overheat in sg weather :s22:
resolution both 4k, but the actual task at hand are very different for decoding video and playing games. the video decode is much simpler to execute since the visual output is already predetermined (as the video file) vs having to render tens of frames of a game scene per second on the fly.
sacar101
Euqorab
Sorry
Any mini pc recommendation? Buyed Mac mini but not used to it siah.
budget $800
Should I buy P51 Asus but no Os must spend $200 extra to buy one
Or should I go brand made?
NightRaven49
Where did you find the psu price on dynacore as I can't find in on their price list pdf or their website.
it is in their price list pdf, page 2 1st and 2nd column from the right labelled power supply. the core reactor ii ve is listed for 129 (under the thermalright tg-750w), while the cooler master v650 v2 gold is listed as the cm v650-650w v2 white 80+ gold (under the cm v sfx platinum 1100w) for 119 in their currently latest 5 oct pdf.
budget $800
https://forums.hardwarezone.com.sg/threads/mini-pcs-2023-any-good.6859514/
$800 more than enough for the latest mini pcs running zen4/5.
u dont need a license to use windows. got much cheaper ways to get also (<$10).
soreloser
got free method also :ROFLMAO:
sacar101
Saw it thanks! Previously I really blind, totally never see the 2nd column of PSU.. :s22:
Yevin227
hello all,
thinking of redoing 2 rigs for me and my wife.
i am running an AW3821DW and my wife a AW3420DW and 2x Dell Ultrasharp 27inch at 1440p each.
We do video editing, excel, word documents, photoshop and looking to run some basic AI tools.
Any rig recommendations for below 1.5k-2k each?
I play DOTA/Call of Duty but would like to try some AAA titles like Black Myth Wukong but not sure if I need to up my budgets to run at these resolutions.
Thanks all!!!
deepblue_82
hello all,
Thanks all!!!
paging @NightRaven49 bro...
the monitors are g-sync but currently a rtx 4070ti super is kind of like 1.2-1.5k i think
if ur wife not gaming that high end can look at rx7600xt .....
