alexandraThe periodontal specialist you went to subsequently, NDC or private ?
Is Mewing for better sleep?Anyone heard of mewing
https://g.co/kgs/YAJBtnC
And heard of adult tongue tie release? It's frequently done for young kids having difficulty breastfeeding
Technically shouldn't have much side effects but you should be mindful ofI'm quite busy so I'm only able to go for my braces appointment every 4-5 months. Is there any negative side effects for my teeth?
So many leAny dentist to recommend around central area for polishing and scaling? Can claim from company before the year end.. usually I go JB do lol. Tia
SIC please....So many le![]()
Always good, especially you are developing early sign of perio disease.When a dentist recommends deep cleaning
is it necessary?
No unless you are super scared of pain.does filling cavity
Required Local anesthesia?
How old is the child?Hi @Venusys,
Do you have recommended dentist for brace for child? Preferably in Punggol or near this area, with reasonable pricing. Would appreciate.
Thank you.
Turning 13 soon.How old is the child?
Hi learntoforgive, thank you for the question. I cannot directly address the condition of the tooth and gum situation unless CT scan is used. X-ray cannot really see much details for your case. This is what I would do for a piece of mind.Hi Venusys,
I have an gum abscess situation at my lower left back molar recently. I have visited dentist for 1st round and had given 2 type of antibiotic and painkiller was prescribed.
1) Finished my prescription, face no longer swelling , pain fully subside. But gum abscess is still there
2) Visited the dentist again to do x-ray and deep cleansing of teeth. Doctor mentioned x-ray seems nothing wrong for my root canal done many years (>5 years). Doctor just mentioned to use salt water to gargle and abscess situation should improve although he did also mentioned x-ray is 2-D and might missed out some details.
My concern is from start till end is about 2 months for the situation, I aint feeling any throbbing pain at the back of my lower left molar and all seems good except that my gum abscess is still there-just that the abscess has become smaller.
-Want to seek your recommendation on this on what should I do? Live with the gum abscess? Continue to gargle with water? Can i recover? Generally how long doe it takes?
Thank you.
Is it something your child needs or you want for your child so he/she look presentable for the teeth?Hi @Venusys,
Thank you.
Or is it affecting his or her biting, speech or sleep?
I think you need to be mindful that braces could have effect on the jaw of your child in the future. One could end up with having Jaw stress or TMJ pain for the rest of his/her life.
For child, there are alternatives to braces that could yield result but gentler. They are call aligner for children. I will recommend pediatric dentist or dentist specialise with children to help with your case. Unfortunately, they may not that cheap if cost is your concerns.
All the best for your child.
Sure, it is almost standard to have tooth removed for braces work.Thank you for your feedback.
It is necessary as suggested previously by a dentist more than a cosmetic want. Based on previous x-ray, my daughter's molars are cramped too much, and initial suggestions of dentist that time was to remove a couple of cramped tooth (one each side) and put brace so that there will be space for remaining teeth to align properly.
