yuri2
- Nov 30, 2002
My latest drama starts with finding the floor mat being wet. Then I found the leaking water is due to FCU... again. I took out a wet vacuum to suck out some slime at the bottom of the drain pipe. All the water clogged up came rushing out. I had neglected to put the condensate pill regularly.Using condensate tablet to test out on my AC. i tested it for 4 cycle aka 4 month.
in short the tablet if you partly remove drain pan to put the whole tablet in or if you dont want remove drain pan, it will work also but you need to chop into 8pcs (4 pc or half a tablet i have mix result)
so using this
if you remove drain pan you can put 2 inside here at the very end of the corner
if you cut a tablet, you need to cut into 8small pcs, or 16pc for 2 tablet
it will rest on the side of the drain pan
water will then turn green. but it lasted for 2 to 3 times as in it dissolve fast
not sure if it work or not, this is my drain pan when nv been clean before for over 8 mth. it still wet cause my on my AC for over 15hr and then 45min of fan mode ( it seem 45min of fan mode is not enough, maybe 1.3hr of fan mode)
Next, the aircon is not cold yet again. I used this Starmex 24/7
So I used the Bosch pressure washer with soap solution (Supersteam 306) .
Unbelievable; the black stuffs that came out during the washing.
Now FCU is cold again, even at setting of 27 deg.
I find that I need to use the pressure washer with soap solution, to really clean it out.
I tried without soap solution, or without the pressure washer (just tap water), it doesn't clean very well.
