crimsontactics
- Nov 25, 2009
You referring to mine or Bro @kw442?You use vinyl flooring ah? How you keep that white color floor clean?
After ish better bah Bro Drz88.Need some advice here.
Should I install new water heaters in both toilets before or after the HIP?
Thanks in advance.
All the best Bro Apparatus!Mine will start next week
Thank chiu for your good advice Bro JoeBlackCoffee!Another tip:
Buy a small basket (with holes at the bottom to go through) to carry your toiletries for you to bring down to the toilets downstairs
You can also tie a string and/or get a hook
So you can hook them inside the toilet
Don't worry about the toilet. I've seen some of them in various HIP projects. They're generally clean. I'm guessing they have people who clean the toilets throughout the day
Mybfd Bro RinoaX!Still unpacking....wanna cry already bro
Dun worry.Still unpacking....wanna cry already bro
Wa you still dare use "mybfd" ah....later 60 year ban.Mybfd Bro RinoaX!
Just have to power thru...![]()
Life ish hard on us Bro RinoaX...Wa you still dare use "mybfd" ah....later 60 year ban.
Yeah they very desperate for us to sign off Bro JoeBlackCoffee...I bought many plastic sheets (for painting type) and masking tape (dun buy cheap type)
Paste from floor to ceiling to seal up:
Whole living room
Kitchen cabinets (also floor to ceiling) , fridge, washing machine
Because the dust from the hacking will fly all over. The sheets are thin and light. But will drop when wind blows because the main door is always open as workers come in and out. So get decent masking tape.
Then use wet cloth to cover the gap of your bedroom doors.
My mother and I stayed in our rooms during the whole HIP
if my sick father was still alive, we would have moved him and my mother out temp.
During last fee days decision maker better stay at home:
Tell the where to install the fittings you want. What position, high, low...
Check every inch because they like to cut corners, lazy and take shortcuts
Cos I saw chips and cracks on the tiles. They pretend never see. So I told them to hack and replace the tile.
One of them also dropped a tool on the tile when installing my heater. Then got a chip. I told them to replace.
They die die want you to sign off desperately. So if you're not happy, don't sign, tell their supervisor.
You only see supervisor on the last day when signature is required from you.
Then my side they ask u take photos with them with a thumbs up sign![]()
Thanks for the advice.
while I don't know where to move them, I will look into it. Was planning to lock them in the study room and bed room. Because shifting them to an unfamiliar place might frighten them.
You have to move the animalsAll the best, bro! Please update us. Moi HIP coming soon too. I am worried coz I have cat and dog and some other small animals....no idea what to do.....![]()
I am sorry to learn that the noise accelerated the deafness of your dog in its final years.You have to move the animals
My upper floor guy is loaded , like to redo his floor every 8 years for fun
It accelerated the deafness of my dog during its final years.
That is just 1 floor with limited jackhammer
The toilet HIP they do 6 jackhammer at once , 2per floor x 3 floor , much louder and more days since u start to hear it few days prior as they go from upper to lower floor, multiply by adjacent units left right.
I expect it's not survivable to animals. You have to move them out to other place , find other animal lover.
I saw others bring their cat dog duck all away. Only low budget cat owner bring the cat back daily not paid pet boarding.
