kimsix
- Jan 6, 2009
$888 huat ahyolo! I think will be under $800![]()
yeah..i think pat lacks diplomacy for a CEO..
Affordability is subjective.I wonder if it is affordable
Agreed as of now even first gen 5800x3D I hardly experience CPU bottleneck and the cost of new platform upgrades abit hard to justify for now.Affordability is subjective.I won't think it should cost a lot taking the 7800X3D as a reference, but I won't want to spend that much money on a CPU to be honest.
hope pat can beg trump for more funding soon! Maga beat tsmc is near!![]()
I think if you are gaming at 1080p or lower, you can see the performance bump. But by the time you hit 1440p, that benefit starts to diminish quickly. And I think most reviews tend to test CPUs at low resolution just to showcase the max potential, which I think is not fully representative of all resolution.Agreed as of now even first gen 5800x3D I hardly experience CPU bottleneck and the cost of new platform upgrades abit hard to justify for now.
I see people here looking for qhd/uhd oled and mini led monitors. I wonder why some are very excited about this cpu. No doubt the x3d crushes the rest in fhd. But do you think the higher cache size has any effect at 4k and above, even on next generation gpus?I think if you are gaming at 1080p or lower, you can see the performance bump. But by the time you hit 1440p, that benefit starts to diminish quickly. And I think most reviews tend to test CPUs at low resolution just to showcase the max potential, which I think is not fully representative of all resolution.
If your GPU is not holding performance back, then you should see some performance boost. Your PC is as fast as the slowest component in there, for a given workload. So if you use a 9800X3D with a GTX 1060 as an extreme example, even at 1080p, you will run into a bottleneck very quickly. To resolve this, you need to upgrade the GPU to reduce or eliminate the GPU bottleneck. But the bottleneck may move to other components like CPU or memory speed, etc.I see people here looking for qhd/uhd oled and mini led monitors. I wonder why some are very excited about this cpu. No doubt the x3d crushes the rest in fhd. But do you think the higher cache size has any effect at 4k and above, even on next generation gpus?
So to your question about the benefits, I think it depends. If you pair this CPU with say a RTX 4090 or 5090 for example, and you use an OLED 1440p display, then I think you should see some improvement. Another scenario to consider is if you run DLSS or FSR, you are technically not running at native 4K, so you should also reap some benefits from a faster CPU. Most reviews I noticed only show 1080p testing, but that is an indication that it can benefit upscaling solutions.
This whole intel core 200 now is good if you just on your PC and run cinebench and nothing else.
Or you do encoding work.
Hopefully Intel can fix it. But I do think its very strange when internally they tested with a right combination of BIOS and OS version to achieve "good performance", yet did not roll it out at the time they release Arrow Lake. So looking forward to see what they can do to optimize it further.
https://www.tomshardware.com/pc-com...ing-performance-is-due-to-optimization-issues
same thing with zen5, from zen0% to zen5++% with software fixes
Intel i feel have more room for ARL to grow. The cpu design looks complexer. As shown in sm, 285K is a beast in certain parts of modern games!
This result may be quite misleading because I feel the bottleneck is likely on the GPU with this sort of resolution and graphical settings. The fact that all the results are mostly capped at the same level is a clear sign the CPU is no longer the bottleneck here.same thing with zen5, from zen0% to zen5++% with software fixes
