- Sep 16, 2018
Thanks xiao fan. China TX-AX6000 works well for me. How to buy and deliver to SG?
You can buy from Taobao/Tmall. Shipment/GST will apply.
12.12 offer may be cheaper.
Bro @xiaofan is the BE86u still as good as the previous gundam 86u? I still like that 86 series.If you do not mind no local warranty, then Asus China version is much cheaper at RMB 2049 (plus shipment and GST)
https://www.asus.com.cn/store/gallery-476.html
Take note 11.11 offer just finished. You may wait for 12.12 offer.
TUF-BE3600 ==> RMB 499 (no offer)
TUF-BE6500 ==> RMB 799 (no offer)
RT-BE86U ==> RMB 1629 (usual price at RMB 1799)
RT-BE88U ==> RMB 2049 (usual price at RMB 2199)
Thank you xiao fanYou can buy from Taobao/Tmall. Shipment/GST will apply.
Other forum is reporting ASUS router malware, one of them had 100% CPU usage on 1 core. Although only reported on AC and AX routers, might affect newer routers as well.
There are fixes in the latest firmware. Do keep your firmware updated.
https://www.snbforums.com/threads/malware-damaging-asus-routers.92752/
Just carry out another check to confirm the Asus China model has exactly the same FW as Asus Singapore model (Global model).
From the SHA256 checksum, we can see the firmware file is exactly the same.
Asus TUF-AX6000
https://www.asus.com/sg/networking-...00/helpdesk_bios?model2Name=TUF-Gaming-AX6000
ASUS TUF-AX6000 Firmware version 3.0.0.4.388_33427
Version 3.0.0.4.388_33427
41.11 MB
2024/11/06
1. Strengthened input validation and data processing workflows to further protect information security.
2. Enhanced AiCloud password protection mechanisms, safeguarding against unauthorized access attempts.
3. Enhanced device security through improved buffer handling in connection features.
4. Refined data handling processes, ensuring secure and accurate information management.
5. Enhanced file access control mechanisms, promoting a more secure operating environment.
6. Strengthened certificate protection, providing enhanced data security.
Please unzip the firmware file, and then verify the checksum.
SHA256: 2b80dd687b38a7c6230cb5c0136a14353046bcec01b2ce999f51ab110d4b7bb7
Asus China TX-AX6000 天选路由器
https://www.asus.com.cn/networking-.../tx-ax6000/helpdesk_bios?model2Name=TX-AX6000
ASUS 天选游戏路由 固件版本 3.0.0.4.388_33427
41.11 MB
2024/11/06
1. 加强输入验证和数据处理流程,进一步保护信息安全
2. 增强了 AiCloud 密码保护机制,防止未经授权的存取尝试
3. 透过改善缓冲区处理来提升设备安全性
4. 增强数据处理流程,确保安全且准确的信息管理
5. 强化文件存取控制机制,提供更安全的操作环境
6. 强化凭证保护,提供更好的数据安全性
请先将文件解压缩后再用原始固件文件确认Checksum
Asus router malware issue has been reported.
Better to disable AIcloud for now (I am not using this feature myself) and check for Asus FW updates.
I have upgraded my Asus RT-AX86U running Asus Merlin FW.
From here:
https://forums.hardwarezone.com.sg/threads/asus-wifi-7-and-wifi-6e-routers.6952409/page-32
Thanks for the heads-up. This was also mentioned by another forum member whose RT-AX86U was damaged by the malware.
Better to disable AIcloud (I am not using this feature myself) and check for Asus FW updates.
Asus has not released the FW fix for RT-AX86U yet. Merlin has the fixed FW released for Asus WiFi 6 router supported by Merlin, including RT-AX86U. My RT-AX86U is running as an AP after OpenWRT router. But I will upgrade to new Merlin FW over the weekend.
https://www.snbforums.com/threads/asuswrt-merlin-3004-388-8_4-is-now-available.92938/
3004.388.8_4 (17-Nov-2024)
- CHANGED: VPN killswitch will now only be active if the
VPN client itself is enabled. If you stop/start
the client yourself over SSH, you need to also
update the enabled/disabled nvram setting.
- FIXED: Security issues in AiCloud (backports from Asus)
- FIXED: CVE-2024-2511, CVE-2024-4741, CVE-2024-5535 &
Implicit rejection for RSA PKCS#1 in openssl
(backport from Ubuntu by RSDNTWK)
Models with unidentified upload traffic mentioned in SNB Forums reports so far:
RT-AX86U
RT-AX88U
GT-AXE11000
Models with damaged radios after reset mentioned in SNB Forum reports so far:
RT-AC86U
RT-AX56U
RT-AX82U
RT-AX86U
RT-AX86S
TUF-AX5400
Today I also did a check to confirm that Asus China TX-AX6000 has exactly the same FW as Asus Global version TUF-AX6000.
You can also see that Asus has released the updated FW to fix the AiCloud related issue.
https://forums.hardwarezone.com.sg/threads/asus-wifi-7-and-wifi-6e-routers.6952409/page-33
Did you change the default name and password ? If not, check the bottom of the router for the default credentials. Else, you need to make sure there is definitely no typo on your part.anyone know what is the issue with Asus Router GUI where they keep saying username or password is wrong.
I just did a RMA with the Avertek and the problem still persists
Yup, there is no typo on my part.Did you change the default name and password ? If not, check the bottom of the router for the default credentials. Else, you need to make sure there is definitely no typo on your part.
You just got a replacement right ? Unlikely the new unit will have the same exact problem.Yup, there is no typo on my part.
I suspect there is some settings on the router or my pc causing the problem...
Think my ax 11000 pro just died. MyRepublic set. No wifi and lan connection, did hard reset also.
Yes correct. I am going to Asus service Center in Kallang now. Hope can do 1-1 exchange smoothly. MyRepublic sent me my invoice and told me to proceed, also called the Asus service Center they said no need appointment.Since this is local set you should be able to get a new replacement set since it should be within 3 years warranty period.
You may want to contact MyRepublic first and then see if you need to get replacement from MR or Asus Singapore.
