sacredrays
- Feb 1, 2009
bo bian ba, i think you in middle of 2 weak coverage. if you are in either room with the deco unit (upstairs), both surf net ok?If upstairs and not in my room, can load. It’s only in my room then have issue
and usually the speed slows down a lot around midnight. I see from my Deco app that around midnight the signal the router is receiving will drop also
the other weird thing I noticed is that: when I try to login into eight myaccount for my mobile number, can request for OTP and receive OTP.
but when I try to login for my data only plan, request for OTP can only be done if I turn off WiFi on my phone and use my mobile number data
